Ok dokie, here are my results from Feb 2004.
I was told at that time that the cat was bad, but since I had reached the repair limit, I ended up with a conditional pass in the end.
Test is comming up again now. I've already bought a new cat and mid pipe with resonator cause mine broke off at the muffler flange.
After searching and reading on here for an hour I've come to the conclusion that my cat probably wasn't the problem back then.
I've recentley replaced my thermostat which I now believe may have been my problem all along as the car was never heating up fully until on the highway and I was having all kinds of cold idle trouble.
However as you can see, I had no trouble with the idle part of the test.
My main problem would seem to be running rich while driving. I found nothing about adjusting that though. Could that have been as a result of the lower than normal operating temp?
