I recently purchased a floor jack and a pair of jack stands (2-ton), hoping to be able to get under the car.
The lift range of the floor jack is 14". I used the jack on the front jacking point (the big hook). When the jack reaches the highest point, I can barely insert the two jack stands at the jacking points behind the front wheel, and the jack stands are at their lowest height (about 10"). I don't think that's enough for me to go under.
I used ramps before, but it's a PITA to use. I once drive over the ramp and had the ramp stuck.
What do you use to jack up the car in order to do some work from underneath?
Should I consider more expensive jacks with more lift height? or there are some other tricks?
