Results 1 to 15 of 15
Thread: Engine To dO's
    Question Engine To dO's
    ok, few questions. First ima tell ya right off i am not a pro at cars or engines, by far i might ad. anyways i am doin some mods and stuf to my engine, i was wonderin about the small filters you can buy that tie on to the engine where the air intake thing is. what the purpose for this and what do i gain from it.
    http://www.quickclic.net/~coaster/i1.html im talking about the filter right above the H emblem.
    also what do i gain by adding a accel coil.
    last but not least how in the hell do i adjust my carb. my car sits and has a putting effect when it is ideling. aslo sometimes the high rpm idel doesnt seem to disengage after the car has been on for a bit. i have to tap the gas for it to idel low. how could i fix this.
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    is that the pcv return with that lil filter on? weird,
    '85 lude
    houston
    hittin the gas to knock the idle down is the way it is supposed to be.
    dont get those little filters they are not good for the engine.
    a coil alone will not give you much of anything. not likely to be even noticeable
    1989 Accord LX
    k, that little filter, not entirely sure, but I think it adds an even more unrestricted way of venting crankcase gases. It just puts it strait out to the atmosphere instead of sending it through the intake to get burned again.
    Next, our cars, if you let them idle long enough, do automatically kick down. That's what all that extra linkage is for. If you'r impatient, you can kick it down yourself. If you go driveing around, and it doesn't kick down right away when the engine is fairly warm, than the kickdown linkages are sticky. Get some carb cleaner, take your air cleaner houseing off, and completly soak all the linkages with the carb cleaner. If that doesn't work, try a different brand. If none of the brands work, or if you're tired of buying carb cleaner, than rebuild the carb. rebuliding a carb can seem kinda of scary, but it is not that difficult. Just have a large open space, with room to organize the parts. Have some solvent for soaking and compressed air for blowing the solvent out of the passageways.
    Last, getting a coil is noticable. But, getting a coil, with 8mm wires and some hotter plugs with a larger gap (not too large though) is better. In canada, the accel coil was cheeper than the stock one (bout $43 for yellow) and the 8mm wires could be anywhere from $40-$150. A set of 8mm NGK wires is $41.49
    89 Accord LX: Fram air Filter, Flipped lid, Bosch Platnum plugs, NGK 8mm wires, Accel coil (8140).
    Things to come: Front and rear sway bars off SEi, Front and rear disc brakes off SEi, struts and springs, 4-2-1 manifold, 2.25" custom exaust, 16" rims (ROTA circit 8) with 205/45/R16 rubber (Falkon), clear taillights, new paint (this summer), custom cold air intake with box, oh ya, and fancy blue vacum lines
    2005 Mazda 3
    Ontario Canada eh.
    that PCV filter thing is a waste of money, and besides don't our cars already have a pcv filter?
    89 coupe/ 06 TL 6spd
    Vancity
    what i usually do to make it kick down sooner..
    as soon as you first start your car, like in the morning, give it a quick punch... that will disengage your choke..
    it stays reving at a high rpm because your choke has not yet released...but if you give it that quick punch in the begginning.. instead of driving off, it will idle down sooner..
    R.I.P Spoon Se-i 01/17/04
    88 Lxi/ 5spd
    Tennessee
    yeah the thing recylcles through your air intake where your air filter has already cleaned the air....by seperating this device from the air intake (cai or aftermarket piece) you need to add its only little filter to stop dirt from enter the engine. It doesn't work as effeciently but as least it still lets blowby out. You see the orginal is under vacuum from the engine so the engine helps suck out the gases why with the filter it haves to just flow out under atmospheric pressure.....glad i could help
    In the end...it doesn't even matter.
    88 Lxi, 5spd swap w/ Aasco 8lb flywheel/Cai,AccelCoil,NologyWires,SilverstoneSparks/DC421,ColtCam,Remachined Head&Tb...NitrousWorks 40shot
    LXi User 2Fast_Fiero's Avatar
    1988 RED Fiero GT, 1985 BLACK Fiero GT
    Albuquerque, NM
    Well, I was gonna make my own Cold Air Intake System, and that lil tube that comes off the Valve Cover and travels to the intake, Do I need to make some sort of connection for that tube into the intake that I'm making? and there was also 2 pipes comming out of that lil box up in the left hand corner on my pictures, do those need to be connected?
    well lets see. to get the air to the valve cover it has to go through the airfilter box. so all it does is suck air, so why it is not good just to putt this little filter. i have seen many times this kind filters on V8 engines. i think it is ok to have them. and you can get them at any autostore.
    88 Lxi/ 5spd
    Tennessee
    its not as effective cause its no longer under vacuum......but they work just fine
    2005 Mazda 3
    Ontario Canada eh.
    whatever you decide, just make sure your sure about what your doing as to not cause serious damage down the road
    1988starter
    Guest
    I had one drove with it for 10 min found no power increase in fact a little drop and got my10 bucks back
    88 LX Action
    Podunk, Alabama
    yeah but you need it if you make your own intake, right?
    real 3geez http://www.3g-generation.com
    i sold the honda. now working on a car with little bit more potential, an 88 supra. i still stop by occasionally.
    yeah you will need it if are making your own intake or you have fliped lid.
    Albuquerque, NM
    Yes, I'm designing a TRU Ceramic Cold Air Intake, I'm taking what Team Del Sol did and tryin to figure out something more effective since thier cold air intake blew away name brand cold air intakes, I wanna make it better HEHE:fight::badass:
  1. Replies: 14
    Last Post: 03-12-2010, 06:20 AM
  2. Found a B20A1 engine in engine-test stand
    Last Post: 07-16-2005, 07:54 PM
  3. need pictures of engine bay to help me fix my problem with engine swap
    By jerky_lxi in forum Interior & Exterior Care
    Last Post: 06-06-2003, 08:43 PM
  4. Replies: 11
    Last Post: 06-19-2002, 02:49 PM
