i have a 1989 honda accord lxi, when cold everything runs fine, but once warm the car stutters when you press the gas and kinda jerks, also once you turn it off you cant restart it for about 10 min- 1 hour. it will crank but not fire. cold it fires right up. also while driving the temp gauge will spike all the way up after a few minutes it will drop to normal, dont know if this is part of the starting and stuttering problem. once warm and sitting still if i press the gas lightly it sounds like it will die out but then comes back. i have re soliderd the main relay and problem is still there. the car while sitting still and warm idles fine but when gas pedal is pressed the rpm's drop car almost dies then they come right back up again. im lost!!!!!
