Results 1 to 7 of 7
Thread: Headlight low beam probs
    Feb 2003
    1950 Plymouth daily driver, 1967 Riviera, 1951 Buick Roadmaster with a 455
    Spokane WA
    Question Headlight low beam probs
    Hey I am having some problems with my low beams on the 87 Lxi. I had the car since June and just recently it started blowing out the low beams. The highs work just fine, but about once a week now they are killing the new headlights. Anyone got any clues on this? By the way, nothing has been done to the car.
    Feb 2004
    89 accord lxi
    down by the bay
    Re: Headlight low beam probs
    look for a short on the wiring that is routed around the pop up assemblies.
    88-89 had a plastic retainer that held the wire loom to the pop up, but 86-87 doesn't so it's more likely to get chewed up over time from opening and closing the headlights.
    LX User Honda-Master's Avatar
    1980 Porsche 928
    Galaxy
    Quote Originally Posted by Strugglebucket
    good call ,,,,,,I have repaired a shit load of those wires coming apart and shorting to ground,, thus blowing the fuses ...
    remove the lamps, remove the pop up cover and look at the wiring back there , you might have to peel the harness back a bit to locate break in the wires ..
    1988 Honda Crx Dx Mini-Me
    Columbus, Indiana
    yes it's a short. def.
    (don't you hate shorts?)
    Feb 2003
    Spokane WA
    Alright thanks for that info, but they have been stuck in the up position since I got it. So they havent been moved or anything
    1980 Porsche 928
    Galaxy
    you don't have the switch on the dash pushed in do you ???
    Feb 2003
    Spokane WA
    Hey Honda-Master, I am smarter than that dude....when i bought the car the previous owner had rearended a pickup and rearranged the whole frontend, so the headlights are stuck in the up position. And yes, I did check the wires and nothing is even uncovered
  1. One low beam headlight not working.
    By Legend_master in forum 3geez Accords
    Last Post: 04-09-2012, 08:16 AM
  2. Headlight Sealed Beam H4 conversion
    By 1stgen!!! in forum 1geez Accords
    Last Post: 12-16-2011, 04:07 PM
  3. Low-beam headlight problem
    By Haxxorz in forum 3geez Accords
    Last Post: 09-24-2010, 06:30 PM
  4. Low Beam Problem
    By kaltenacht in forum Interior & Exterior Care
    Last Post: 06-25-2005, 07:53 PM
  5. Headlights not working on low beam
    By Luis 89LXi in forum 3geez Accords
    Last Post: 10-26-2004, 03:59 PM
