Results 1 to 25 of 25
Thread: Splitfire triple-platinum spark plugs
    SEi User Acid X's Avatar
    Apr 2005
    Azusa, CA - Los Ang. County
    Alright, i tried searching and couldnt find that much info relating directly to splitfire triple platinum spark plugs.. The ones with the v cut into it.
    Anyway, im wondering if they are any good? If not, what are the best spark plugs i can use? I read about resistorless, but also read that they can cause electrical problems. Is this true?
    Sorry to post a thread like this.. Maybe im not reading enough.
    90 CRX
    Re: Splitfire triple-platinum spark plugs
    platinum anything isnt good for our engines for some reason. i think it has something to do with a low compression ratio. stick to something with a copper core. the ngk iridium's supposedly work well on our engines. but really they arent worth the money you'll spend. regular splitfire's are alright. i stick with ngk V-power plugs. they last the longest out of the other kinds i've tried.
    Apr 2005
    Alright, so for sure i should stay away from platinum.. Hum. What kind of plugs would give me the best gas mileage and performance?
    90 CRX
    Vanilla Sky's Avatar
    1999 Penalty Box
    personally, stick with the NGK v-power plugs, but play with the heat range.
    resistorless plugs only cause problems in systems that have little or no tolerance to electrical noise. supposedly resistorless plugs will usually still work fine as long as you have proper wires. just something i read somewhere on the internet (i think a20a1 (mile) posted the link), so you may not want to really take a lot of stock in it. the idea is that the resistance should be in the wires, not the plugs.
    LX User 89accordex4dr's Avatar
    89honda accord ex 2.0l
    southland,new zealand
    I got a set of regular Split Fire spark plugs (part number S F 6 C), yeah a bit pricey but they are the best set of spark plugs I'v ever brought, more throttle response and they have a three year warrantee, great stuff
    Apr 2005
    You have the regular non-dual tip ones? Hmm.
    Quote Originally Posted by Vanilla Sky
    The heat range huh? I'm running stock nearly other than my axle-back exhaust and my CAI. The next thing im going to do is replace my spark plug wires after i do my plugs. After that i want to finish my exhaust all the way up to the header. What kind of heat range should i go for?
    90 CRX
    yeah the non-platinum one's, still got the v slpit
    Apr 2005
    Do you know if they perform any better than the NGK v-powers?
    90 CRX
    The platinum will just last longer because it wont wear out as fast as the copper, but the platinum has more resistance then the copper. Same plug, just longer life... but you can always put a file to the copper plugs and bring them back to spec.
    Apr 2005
    Alright. I bought the non-platinum ones. I'm wondering if anyone knows if i have to gap them?
    90 CRX
    1999 Penalty Box
    yes, you do. i think the stock gap is .044.
    Apr 2005
    Shite. I dont have a gapping tool. Should i gap it to stock value or go a little higher or lower?
    Also, what's your guys' take on Cran Cams 11mm Spark Plug Wires? I bought some off of ebay and i'm wondering if they're good quality.
    90 CRX
    1999 Penalty Box
    well, if you have a stock ignition, then a stock gap.
    Salem, Oregon
    Okay, guys... I'll post this again. http://vskabuki.blogspot.com/ The idea is not to just have resistance in the wire or the plug, but to have MATCHED IMPEDANCE throughout the ignition system, for maximum power transfer. It's very much like Speakers and Amplifiers. You wouldn't use 8 Ohm speakers on an amp rated for 2 Ohm output, because it won't operate properly, and could blow one or both. Just use OE stuff. Don't fuck with Bosch or Splitfire or any of that crap...
    Apr 2005
    I tried NGK wires and they broke on me.
    I might as well just try the Crane's. I mean, they were 17$
    As far as plugs, i've heard good word from a few members here that they are pretty good plugs. Not to mention they make more sense having that open area at the top to more easily access fuel in the cylinder.
    90 CRX
    DX User davke's Avatar
    what kind of plugs would be good for b20a1? can i put from a20 ngk v-power?
    Feb 2004
    89 accord lxi
    down by the bay
    Quote Originally Posted by Acid X
    if you have a header the ngks don't hold up to the heat very well, but they have the best fitting boots for the cap. the crane wires are really durable, but the boots don't fit on the cap very well. i wound up putting different boots on them from another set of generic oem wires i had.
    Apr 2005
    Cool, thanks for the info struggle.
    90 CRX
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Use nippon denso man. They are JDM. I have some regular ones in my car right now and they make a big difference. I would also go with the NGK OEM sparkplug wires.
    LXi User superaccord's Avatar
    '89 honda accord lx-i
    colorado
    I'm with Bullard!
    Check out my Cardomain page for mod list and pictures of my 3GEEZ!
    My Cardomain Page With PICS!
    *New Colorado 3Geez meet comming soon*
    Apr 2005
    Well, i already bought the stuff, lol.
    Anyway, i put the plugs in and the throttle response seems greatly improved. It seems to accellerate smoother and maybe a tad bit quicker because of the improved throttle response.
    I haven't gotten the spark plug wires yet, so i dont know how they work, but i'm happy with these splitfires.
    I'll fill you guys in when i get the wires too.
    90 CRX
    Glad to hear they work for you as they did for me
    SEi User PortugalFocus's Avatar
    Sep 2003
    '13 Civic Si 4dr / 05 Saturn VUE 2.2L 5-Spd
    Clearwater, FL
    I use NGK's and Autolites. Autolite's in the domestics and NGK's in the imports. They just do very well in the applications I have used them in.
  1. Spark-plugs
    By 89accordex4dr in forum 3geez Accords
    Last Post: 01-19-2007, 08:45 PM
  2. Help With Spark Plugs
    By dalinxz in forum 3geez Accords
    Last Post: 04-25-2006, 06:52 AM
  3. Spark Plugs
    Last Post: 04-03-2006, 11:14 AM
  4. Spark Plugs
    By FyreDaug in forum Performance
    Last Post: 11-28-2005, 07:52 AM
  5. Replies: 4
    Last Post: 11-17-2003, 02:57 AM
