Results 1 to 4 of 4
Thread: dropping the tank
    '85 lude
    houston
    dropping the tank
    anyone ever drop the tank on their car ?
    i let both straps down and it didnt move. is it just stuck or am i missing something.
    i did pull the little plugs under the backseat and it has some really soft tar under there. is the thing tared on ?
    carotman's Avatar
    Montreal South Shore
    When I did my EFI conversion, I dropped the tank of my parts car.
    Other than the 2 straps, nothing "holds" the tank in place (at least on an Accord)
    The only thing that might prevent the tank from dropping is
    1- Fuel lines
    2- Fuel pump wires
    3- Rusted out crap
    Make sure all the lines are disconnected from the pump and it should drop.
    Anyway, you should at least see it sag if you remove the straps....
    I need these parts!
    '85 lude
    houston
    nope, it fell down like a cm. maybe. i pried on it for a while with a big bar, but it wasnt moving much more.
    so i put it back together and ran my return line to the small filler pipe.
    i'll do the tank later. i just wanna have it cleaned out before i put my new engine in.
    PhydeauX's Avatar
    Eastern Penna
    Its just the tar, give it a tug.
    andy
  1. brake pedal dropping
    By 1989 accord lxi in forum 3geez Accords
    Last Post: 09-01-2012, 11:34 PM
  2. Dropping in for useful info
    By fettcols in forum Newbie Introductions
    Last Post: 12-26-2005, 11:51 PM
  3. Dropping transmission from car (automatic)
    By 95AccordEXR in forum 3geez Accords
    Last Post: 05-18-2003, 03:19 AM
  4. Dropping downside...
    By CARBurn in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-27-2002, 09:33 AM
  5. dropping the gas tank
    By rbeaud in forum 3geez Accords
    Last Post: 08-14-2002, 10:00 AM
