i live in australia and its in the middle of summer rite now so its damn hot, and my ac wont work,i had a previouse problem with it, where the power steering pump's belt had rubbed on the wires and split the blue wire that goes to the diode pack, after i fixed that it worked beutifly, but i tryed turnign it on 2day and it wouldnt work,the ac light lit up on the climate controll but nothing happened. i cant figue out what the problem is, relay is fine, diodes are fine, clutch dose enganes coz i jumped it manualy while the engine was running and it dipped the rpm, i have no idea, i dont think it needs re-gassing because it was damn cold when it worked, and also, just another little question, when should my fans kick in, ive never realy had the temp above 2/3rds but i have never seen the fans on
thanx for your help fellas
