Results 1 to 18 of 18
Thread: Flip Up Lights
    LX User AccordRacing21's Avatar
    1989 Honda Accord Coupe LXi
    Sutherlin
    Flip Up Lights
    Before I got my car the right front corner was hit. The previous owner put a headlight assembly from a junkyard in, but it still doesn't close right. I've been looking at it for months and it doesn't look like it's the right light. Is there any difference in the headlight assemblies between the years of the 3rd gen, or the model? It's an 89 LXi Coupe. I know the front bumpers are different between the 2 and 4 doors so I was thinking the headlight assembly may be as well?
    89 Accord LXi Coupe, Tenzo Type II Titanium Exhaust, KYB GR-2 Struts, 2 JL 10's, New Polor White Paint Job, Accel Super Stock Coil, Boss 318 Black Chrome 17x8 Rims, 215-40-17 Ziex
    Re: Flip Up Lights
    it sounds like it's one from a prelude or something,did he change motors? have you looked at the linkage to see if it's bent? a lot of them from different hondas look the same but aren't. maby a first gen integra too. in my crash cart parts i've got a set of buckets from an 89 lxi and they are the same as my 86 dx.
    Sutherlin
    Re: Flip Up Lights
    No, he used the original motor. I think I'm going to replace it. I hope that will fix my problem. Anyone have a right headlight assembly for sale?
    Re: Flip Up Lights
    do you have a picture of what you are talking about? the 86-89 headlights are interchangeable. also coupe, sedan, and hb are the same in the headlight for the 4 years.
    LX User Soundy's Avatar
    A20A2 2bbl 5spd 1987 Accord LX hatchback
    Pitt Meadows, BC
    Re: Flip Up Lights
    Quote Originally Posted by AccordRacing21
    There's a knob on top of the motor that lets you raise and lower the lights manually... if turning that provides the same effect as the motor running, then the motor likely isn't your problem. It may be the linkage, or as someone else suggested, it may be a light assembly from a different model (I think the Prelude lights are similar, but not the same).
    Agreed, a picture would help.
    Re: Flip Up Lights
    Quote Originally Posted by Soundy
    make sure you pull the motor fuse under the hood before you turn that knob,or the lights will keep going back to the position they started in. and watch your fingers,got a severly bruised finger from one of those sobs
    Sutherlin
    Re: Flip Up Lights
    Okay, I found the problem. The linkage on the one that works right is nice and tight and on the one that doesn't close is all sloppy. When it's shut you can grab it and move it up and down like 2".
    Re: Flip Up Lights
    oh, i should have said something also. if those motors decide to open or close you'd better make sure you dont have a finger in there. i've seen what they can do to wires and even a piece of metal that was stuck in mine. not a pretty picture. take the fuse out forsure. also, i dont see how a prelude headlight would fit. thats like trying to get an RX-7 light to fit in there.
    Sutherlin
    Re: Flip Up Lights
    Yeah, it's the headlight off of a 86-87. The trim doesn't match the rest. I think I'll go to a JY (unless someone has one they'll sell me) and buy a 88-89 headlight and start fresh.
    Re: Flip Up Lights
    the headlight assembly is the same 86-89 all you have to do is change the trim,I have headlight assemblies in my junk from 89 lxis and they are the same as my dx.
    Sutherlin
    Re: Flip Up Lights
    I think mine is messed up though. Would you be interested in selling that headlight w/the linkage?
    Re: Flip Up Lights
    well these are my spares but i'll tell you what i'll do,we have a junkyard that always has three geez sedans in it, i'll find out how much one costs and pull one for you when i get the chance. also check on the site someone almost always has a second car they are parting out. these ones have been modified a bit too for one of my secret projects i'm working on,like my round headlights,shhhhhh!!!!
    Sutherlin
    Re: Flip Up Lights
    Alright, sweet, let me know when you go junk yardin. Thanx
    Sutherlin
    Re: Flip Up Lights
    Okay, I found one of the problems. I feel like a complete idiot, but one of the bolts that mount the headlight assembly to the car was really loose. I tightened it up and it almost closes perfect, it just needs a little more adjustment in the motor, even though it's fully adjusted.
    LX User Cant Stop's Avatar
    1989 honda accord lx ,2006 accord se 2.4l i-vtec 166 hp 5spd
    orlando florida
    Re: Flip Up Lights
    Sorry but DUHHH! first rule of diagnosing is to check for loose stuff,fuses broke hoses etc.
    hey at least it was a cheap fix.
    pic's of project at my homepage: home.earthlink.net/~andyk65
    Sutherlin
    Re: Flip Up Lights
    yeah but it's a long story. It's been messed up the whole time I've had the car, and it used to be tight. When I was messing with it before I guess I didn't tighten it up all the way. It just needed a little adjustment, which I did before, but didn't tighten it so it looked like it did no good at all. Long story hopefully you know what I mean but probably not. Oh well, I know I look like a complete idiot, but it's ok.
    Re: Flip Up Lights
    well at least you found it,i'm glad it wasn't anything expensive, you would have looked worse after geeting another light,going to put it in,then finding the loose bolt. I think everyone on this board has been there done that at one point
    Sutherlin
    Re: Flip Up Lights
    Update: I've screwed around with this thing quite a bit and have it pretty close to looking right again. The large gap inbetween the hood and the headlight is because the hood is bent/a little crooked from being hit. I'll start messin with that now.
  1. Why did we get the flip-up lights?
    By w261w261 in forum Classic Honda Community Chat
    Last Post: 01-03-2010, 02:36 PM
  2. flip lights
    By 1988_5spd_lxi in forum 3geez Accords
    Last Post: 12-10-2003, 07:56 AM
  3. about the flip up head lights???
    By disfunktional8o8 in forum Interior & Exterior Care
    Last Post: 12-22-2002, 09:05 PM
  4. those darn flip up lights.......
    By Jubei415 in forum Interior & Exterior Care
    Last Post: 10-03-2002, 04:15 PM
  5. moldings for the flip up lights
    By chucknice in forum Classic Honda Pics & Videos
    Last Post: 09-17-2002, 02:58 PM
