Results 1 to 8 of 8
Thread: air intake and hoses
    LX User Sporno's Avatar
    1987 Honda Accord LXI
    Richmond ,VA
    a friend and me were putting on a short ram intake and noticed a couple of things.
    1. that there was a sensor on the air filter box - do i have to worry about it.
    2. there were 2 tubes running from some triangular box to the pipe of the old air system - do i have to worry about these withmy new intake .
    i need serious help on this.
    LX User fraza's Avatar
    87 Accord Si
    Australia, melbourne
    Re: air intake and hoses
    i just worked out all of that stuff as i just put a cia on myself, the 2 lines that go into the airbox on the side are fairly important, there then lines that the vacuum system sucks air from to help with idle and what not, so if it is easy u should connect those 2 pipes with a t connector and then run that to the intake, but if you lazy like me,unscrew the little box and leave it haning there with a little nitro car air filter on it, about 4 buks from your local hobby shop, as for the other pipe, thats the rocker cover breather hose, you may aswell find a way to hook that up, because the only other option is to put a breather filter on and they are expensive, and dont last very long
    hope i have been of some help
    dont worry mate, that'll buff right out
    Richmond ,VA
    wait what do i do with thesensor on the old filter box. and i i should connectg up the 2 hoses into the intake
    87 Accord Si
    thats not a sensor, i thort it was aswell but thats just where the vacuum lines sucks air in from
    Richmond ,VA
    really so it wont mess the car up or anything. that scared me to death. what do i do with it all. got any pics of what to do?
    87 Accord Si
    as you can see its the little box unscrewed from, the airbox and its just sitting there with a little model car filter on it, and you can see my pod filter in the background its just attached to the stock u bend, the air down there seems to be quite colg, but i am looking to replace that u bend with a aluminium one soon
    87 Accord Si
    Richmond ,VA
    ya i havent taken the old part off yet, but i eventully will.
    2006 NASA/VCU regional Semi-finalist
    2006 FIRST Robot Rumble Quarter-finalist
    2006 FIRST Robot Rumble - Most Promosing Rookie Drive team.
    2006 Championship Curie division
    2007 NASA/VCU- Regional Winner
    2007 Championship-Galileo
    74+ matches on the feild
  1. Intake install, which vaccum hoses do I need?
    By 87SIA20A3T in forum EFI Tech
    Last Post: 09-23-2008, 06:23 PM
  2. hoses??
    By psdrummin in forum 3geez Accords
    Last Post: 09-19-2006, 12:47 PM
  3. How to Replace Coolant Hoses under Intake Manifold?
    By kw_da in forum 3geez Accords
    Last Post: 09-12-2006, 09:19 AM
  4. where to get extra intake sleeves/hoses
    By GDGuy11B in forum Classic Honda Community Chat
    Last Post: 02-17-2004, 11:45 AM
  5. Replies: 27
    Last Post: 08-13-2002, 09:37 AM
