Results 26 to 50 of 74
Thread: Urgent need HELP B-series Install!!!!!!!
    Re: Urgent need HELP B-series Install!!!!!!!
    Quote Originally Posted by Accordtheory
    I believe the 90-93 and 94-01 passenger side teg axles are all the same. Don't quote me on that though.
    The driver's side is obviously different, due to a different style of intermediate shaft.
    I think all the 94-01 came with ABS and that makes them not work with our application. As for the axles not fitting check my other posts. Also SQ is the SQUAD my axles slid right into the hub with no problem at all so it's kinda odd that you had to force yours.
    SEi User
    south dakota
    What do mean by check your other posts? Does that means once you got the actual passenger side 90-93 axle, it was all good? I hope so..
    I don't think an abs axle would cause problems, but who knows. You can get a 93 teg with abs. It's just a thing that fits over the hub to trigger a hall effect sensor, I don't think it would get in the way..
    Yep that what it means.
    Well I figured out two ways to fix the axle problem. Either use a a 90-93 passenger side integra axle (I had two drivers side axles ) and remove the dust ring on the back of the hub ord use an 86-89 integra passenger-side axle.
    Everything I have read led me to believe that it dose make a difference.
    Jun 2001
    Boston MA
    maybe mine was a tight fit cuz the hub been sitting out side for a while, in i sand everythnig down and lub it up i prob wond have that problem. it did come out pretty good
    S.Q.U.A.D. Engineering
    www.squadengineering.com
    can you guys tell me where the back up switch is located?
    SEi User
    south dakota
    On the tranny..it's the only connector on it.
    p.s. Rywire can Juggle my fucking balls!
    SEi User ICEMAN707's Avatar
    Kissimmee FL
    so what's the final verdict legend master? 90-93 integra LS axles and rear tranny mount bracket work? no need for placeracing axles? this means we could use stage 2 and stage 3 90-93 teg axles then...hell yea.
  8. #33
    Quote Originally Posted by ICEMAN707
    Well there is no problem with the drivers side 90-93 axles, but I will have to get back to on the 90-93 passenger side axle. The hub spins now that I removed the dust ring, but it looks like the axle is a little cramped. I will have to get back to once I get it running. If you were to use an 86-89 integra axle, it would fit much better and you dont have to remove the dust ring.
  9. #34
    UPDATE: I am having a little bit of a wireing issue, but nothing that can't be fixed with a little bit of time and patience.
  10. #35
    Jun 2001
    Boston MA
    dood, can i see a close up pic of your drivers side mount, actuall off of them if you can
  11. #36
    Quote Originally Posted by SQ is the SQUAD
    Yeah I will take some when I get off of work today.
  12. #37
    SEi User
    south dakota
    no timing cover, huh? Me neither.. hey, what hoses are you using for coolant, integra hoses? I haven't even looked at that yet, or if the accord heater hoses will work either..
  13. #38
    theres no need for a timeing cover . I am running the factory upper radiator hose and I am running an integra lower radiator hose, but I had to make it smaller at then end to make it work with accord radiator. As for all the other hoses I used the accord ones.
  14. #39
    Jun 2001
    Boston MA
    have you ever ran over a freshly paved road or some pebbles and you feel the bouncing around in your wheel well. well amigine some of those pebbles getting thrown between your timing belt and cam gear, it wont be nice. the timing cover is there for a reason. but, let me stop preaching cuz ill prob not have one on myself
  15. #40
    DX User civic_90_08's Avatar
    looks good y0...ive thought about doin this myself...my dad is a mechanice and he could get me just about any honda motor i want...hmmm
  16. #41
    my friend has been driveing around without a cover for almost 2 years and has had no problems, so no worries here.
  17. #42
    Jun 2001
    Boston MA
    where are my closeup mount pics
  18. #43
    LX User masterkillalw's Avatar
    1987 Honda Prelude...
    Richmond Va.
    I am not running a timing cover either.
  19. #44
    SEi User
    south dakota
    Well, shit, I was going to put one on, but now I might not..yeah right, I'd be the one to get fucked by not doing it..
    And close up mount pics would have Really helped me, I just spent way too long making a driver's side mount. I'll post pics later..
  20. #45
    Jun 2001
    Boston MA
    com on man, the suspense is killing me
  21. #46
    SEi User
    south dakota
    Ok..my fucking tranny is hitting the side of the bay and it can't really go over any farther, maybe like a 16th of an inch.. or my driver's side mount bracket (90-93 integra style, supposedly) will hit the mount on the car..wtf..
  22. #47
    Oct 2000
    '88 Accord LX-i
    Connecticut
    I pulled/hammered the passenger side of the bay out a bit to clear the tranny. I also am not running a timing cover, but I am putting mine back on because you can not set timing without it. The B-Series uses the a mark on the cover to set the timing, unlike the A-series window style on the tranny.
    '88 LX-i Coupe --- LS/Vtec
  23. #48
    SEi User
    south dakota
  24. #49
    SEi User
    south dakota
    passenger side mount should be done in a couple hours...what do you guys think of the driver's side mount..? I call it the stegasaurus..isn't that the dinosaur that has that big ridge on its back? i don't know shit about dinosaurs..
  25. #50
    Holy shit, that looks really good. I had to angle the motor to get it to fit in the car. Once I cleared everything I placed the motor in there correctly. The rear mount and bracket had to be put on last and the firewall brake lines had to be moved up to allow for the mount to be placed. I didnt have to bend anything to get the tranny to clear, it all came down to moving the motor at the right angle.
  1. need urgent aid.
    By DDRaptor in forum 3geez Accords
    Last Post: 06-13-2007, 07:22 AM
  2. Urgent Help
    By russiankid in forum 3geez Accords
    Last Post: 06-11-2007, 12:40 PM
  3. Replies: 40
    Last Post: 12-03-2005, 05:33 PM
  4. Help!!! Urgent!!
    By 89LXIGUY in forum Performance
    Last Post: 09-24-2003, 03:14 AM
  5. Spoon B-series performace for A-series
    By A20A1 in forum Performance
    Last Post: 01-19-2003, 08:26 PM
