i was looking over the ECU pinouts for the 86-87 and the 88-89 ECU's and i saw that the cylinder sensor and the TDC sensor were both switched around on them. im wondering if those sensor wires are 'switchable' as does it matter which TDC wire goes where, or better yet, is there a specific wire place for each of the TDC sensors. im asking cause i looked at the boomslang subharness breakdown and i saw that one of them should be a TDCP and TDCG. does it matter if those 2 wires are switch around from the ECU to the sensor? same with the cylinder sensor.
