Results 1 to 16 of 16
Thread: Oil Cooler?
    LXi User BensAccordLxi's Avatar
    1995 Eagle Talon TSi Turbo
    Tucson, Arizona
    Oil Cooler?
    Is it posible to get an oil cooler for the lxi? Who sells one if they do?
    Oct 2001
    87 Accord EX , 5spd , Manual
    an oil cooler ! ??? what is that ! ?
    MIKE
    Tucson, Arizona
    You don't know what an oil cooler is?
    R.I.P. 1988 Honda Accord LX-i hatchback
    Tucson, Arizona
    The way an oil cooler works is much like your radiator. You have a line that runs from your engine to a small radiator like disigne.(monted infront of the radiator) The air cools the oil like it does the water in your radiator and then it sends it back into your engine. The idea is simply the same.....Cooler fluids inside the engine=cooler engine temp.=better performance.
    OldSchoolSwap's Avatar
    88 Hybrid Accord LX-i
    Miami, Florida
    You don't need that for now, unless you produce about 500hp or so!
    I would invest in better things
    http://vtecnos.tripod.com
    Member Since 7-9-01
    Do not forget the importance of the oil reaching the operating temperature quick! In fact, an oil warmer will be much more important for our small and heat efficient engines. Oil cooler issue prevails in huge engines and the turbocharged ones, where oil gets very hot quickly and may get overcooked.
    Tucson, Arizona
    I do alot of road racing and I notice the temp gauge likes to run a little on the warn side. I have a few friends who I race with that have said that the oil cooler helps keep the engine a little cooler.
    I understand if your car is not much more than a daily driver that you really wouldn't need an oil cooler. On a tight corse where you don't reach high speeds and you have to run most of the corse 45grand on the tach in second gear, your engine gets hot and the oil cooler will help with that.
    Oct 2001
    thanx for explaining !
    but first try flushing the system coolant !
    MIKE
    Miami, Florida
    Synthetic oil would play a big roll in keeping oil to safe levels. use Mobile 1 fully Synth. if you run hard most of the times.
    Member Since 7-9-01
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    7,500 rpm in second uphill causes my head to squirt oil all over... when i stop or slow down at the top of the hill, all the oil drips down onto the exhaust and a big puff of stinky smoke fills the air.
    I use mobile 1 super syn.
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    I think your engine is trying to tell you something... probably along the lines of "QUIT THAT!"
    -5150
    glorious!
    87 4dr lx, 91 CRX Si, 92/civic/hb si, 94 mustang GT conv.
    b'ham AL
    I think your right.
    87 4dr LX "It was FREE"
    91 CRX Si it was only $500 hehe
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    murderer :fight:
    Miami, Florida
    7500 rpm?? not bad for that engine!
    Checked your site... cam i see hey, why don't you add my link on your page? i'll add yours as well.
    Member Since 7-9-01
    A20A1's Avatar
    Sep 2001
    ok ok... not tonight but soon
    86 Honda Accord LXI HB 5-sp
    Central California
    If your running the needle past the 1/2 way point, I'm inclinced to suspect the effecientcy of the whole cooling system, even factoring in what your doing. And I'd worried about what kind of oil pressure you've got pulling those g's all the time, never did install a pressure guage in mine to check.
    Curious what is your suspension setup?
    Now I d
  1. PS cooler RIP
    By Inferno in forum 3geez Accords
    Last Post: 03-29-2010, 10:45 PM
  2. B20A oil cooler
    By EX-ileAccord in forum 3geez Accords
    Last Post: 07-10-2007, 01:08 PM
  3. Tranny Oil Cooler
    By dalinxz in forum 3geez Accords
    Last Post: 06-03-2007, 12:49 PM
  4. oil cooler idea
    By lostforawhile in forum Performance
    Last Post: 09-10-2005, 08:44 AM
  5. Oil cooler? To do or not to do....
    By AccordSi in forum Performance
    Last Post: 04-25-2003, 02:06 PM
