Results 1 to 25 of 30
Thread: Co2
    DX User Noodle's Avatar
    1989 Honda Accord Dx and 1987 Honda Civic Si
    Now:Arizona Usually:Oregon
    Co2
    ive been reading about CO2 injection alot lately and was wondering if you shot CO2 directly into your carb would it help at all, or would it be bad for it, or would it do nothing at all
    Noodle
    Re: Co2
    Carbon dioxed? uh no. it aint flamable is the easiest way I can explain it,
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    Re: Co2
    so far ive experimented with di-hydro-fluroine ( basically the stuff in the compressed air cans u get at a comuter store or where ever) i was able at the end of the semester to do a few combutsion tests in my schools chem lab and found this stuff does burn quite well only problem it burns unstable, however it has properties like that of freon but im still testing it
    3Geez resident body man
    Owner of Wreck-less auto body
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Re: Co2
    co2 injection is for your turbo intercooler.
    '89 SE-i Coupe
    Awaiting Garage
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    Re: Co2
    yeah its a cheap easy way of intercooler cooling like he said, i have seen in a magazine it dynoed about 30whp on a pretty high (300-500whp ish) setup... so its definetly worth looking into, but probably only on a boosted car.
    Re: Co2
    Right but there using it to cool the outside of the intercooler. Compressed its very cold. You can use it to ship things frozen. I dont think its dry ice but its like it.
    1989 Lx-i Hatchback
    Jackson, NJ
    Re: Co2
    well dry ice is its solid form
    2drSE-i's Avatar
    Oklahoma City
    Re: Co2
    dry ice is CO2.
    '89 SE-i Coupe
    Awaiting Garage
    Aug 2004
    Re: Co2
    Dry ice burns the living crap out of you when you touch it. Basically what boba said is what I've heard and read. It's not super beneficial ona stock low-hp engine but, after you start making some good numbers it's like throwing icing on the cake. Remember they also have the intake pipe ones that you can hook up sequentially. Like one at the begining of your cai then another further down, then a third right before the tb. And all that's coming from the same push of the button. Pretty neat but pricey.
    For Sale:
    T3/T4 Turbo, wastegate, and BOV
    P75 ECU
    Untouched Head
    Port & Polished, 5-angle valve job, bowl and swirl job, Head -$1000 invested in machining alone
    Misc.
    DDR Pad and DDR Extreme
    PS1
    NES
    Needed:
    Dremel
    Money
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Re: Co2
    Don't spray directly inside, but route the C02 lines inside the intake... run a small tube or tubes thru the intake... but do not shoot the CO2 into the intake... the CO2 runs thru the tube(s) and comes out the other end. This will cause the small tubes to freeze and air passing past the tubes inside your intake pipe will be cooled.
    Aim the sray of the CO2 nozzle so that it cools the intake manifold... that way it isn't wasted.
    Just make sure the spray is far away from the intake filter.
    Of course the more tubes you add the more cooling but also the more restriction. so maybe have a 2.5" diameter segment of intake pipe close to the TB where you can drill some holes and run the CO2 pipes thru.
    Aug 2004
    Re: Co2
    wait wait wait so lemme get this straight a20. Instead of paying the like 150 that cyrotech wants for that special circle intake segment*if you don't know what I'm talking about I'll post a link* you can just get some copper *best heat conductor for the money* tubing and then braze a fitting that connects to a line that connects to the CO2 tank? What is preventing people from making homemade kits? The only issue that you couldn't "jimmie rig" would be the solenoid, right? And those you can buy seperate at summit. Could you use a Nitrous solenoid, sometimes you can find those for cheap on eBay. That would be pretty neat instead of paying the total $650+*kit plus intake tube*
    For Sale:
    P75 ECU
    Untouched Head
    Misc.
    PS1
    NES
    Needed:
    Dremel
    Money
    Aug 2004
    Re: Co2
    Quote Originally Posted by cke
    The price to performance characteristic wouldn't be as effective as nitrous injection.
    Yeah but, at least where I live nitrous refilling is so outragesly priced you might as well open up your own filling station. Where as co2 is pretty cheap.
    For Sale:
    P75 ECU
    Untouched Head
    Misc.
    PS1
    NES
    Needed:
    Dremel
    Money
    Re: Co2
    hears some products ive found for the use of co2 there made by cryo2 enjoy http://www.cryo2.com/products.asp?m=sc&cid=1
    89 Accord SE-i, 94 Altima
    Pittsburgh, PA
    Re: Co2
    I know a guy that runs a Cry02 system. You can feel the difference, but you can easily go through a 5lb tank of CO2 in one night.
    94 Altima [KA24DE, auto - 15.9]
    94 Sentra SE-R [SR20DE, 55 shot - ??.??]
    Re: Co2
    u can also go thu a bottle of nos in one night but this is safer and a hole lot cheaper im talk 200 less the nos with a ten lb bottle and all the stuuf to hook it op plus u can get the cryogenic fuel chamber and intake system for cheap
    Aug 2004
    Re: Co2
    Quote Originally Posted by 89se-i
    Ok but is it like just a slight increase or difference or does it sling you back in your seat almost giving you whiplash? Also, what type of Cry02 system is he running. There's different kinds. Also I've been thinking about this. What's keeping people from using like "industry" size tanks. I mean nothing *to my knowledge* is different about those tanks then the small 5lbs and 10lbs bottles. So like the kind that you can get from the dentist that size not the necessarily the size they use to fill up ballons w/ helium. Just a thought so that you don't run out as quick plus youre honestly probably paying a tick for the name brand bottle. I belive the NOS *brand* bottles from Summit are like 120 bucks which is insane! *You're paying for the name, or at least that my opinon* Just a thought
    For Sale:
    P75 ECU
    Untouched Head
    Misc.
    PS1
    NES
    Needed:
    Dremel
    Money
    2drSE-i's Avatar
    Oklahoma City
    Re: Co2
    nothing but weight keeps them from running industry sized tanks
    '89 SE-i Coupe
    Awaiting Garage
    Aug 2004
    Re: Co2
    Ok. Well that's the only thing I could figure but, even then an empty propane tank really isn't that heavy. I mean to get that much more life I doubt 15lbs would effect performance that much. Eh... but what do I know.
    For Sale:
    P75 ECU
    Untouched Head
    Misc.
    PS1
    NES
    Needed:
    Dremel
    Money
    Nov 2002
    Ridin Dirty in New York
    Re: Co2
    from what i hear all the gains are negated because the C02 seems to find its way into the intake air and pretty much cancels any real gains. You can spray alcohol/water all over your intercooler to get a good power gain
    Aug 2004
    Re: Co2
    I think mainly what was being talked about besides the intercooler sprayer is the fuel bar "chiller" and the Intake plumb tube thing. C02 shouldn't get in the intake tube from the intake specific tube thing unless the welds are just really really bad. I just wonder how good the gains are. I mean to me it doesn't seem like its worth it unless you're already pushing a lot of hp. Nitrous for the same price seems to have better effects w/o a doubt.
    For Sale:
    P75 ECU
    Untouched Head
    Misc.
    PS1
    NES
    Needed:
    Dremel
    Money
    Pittsburgh, PA
    Re: Co2
    i only road in the car once, but it felt like the difference from a sumemr day to a real cold winter day. personally i dont think its worth the money.
    also 5lbs is the capacity of the tank, not the tank weigh. the tank is probably 10-20lbs depending on the construction material. the bigger type of tank i think you are talking about, is usually steal and can weigh over 100lbs. As for buying a generic tank, a 5lb co2 ank goes for about 60 or so.
    I have been thinkign about making a diy system like cryO2. I dont know much about gas tanks, btu i think you need a dip tube, so the CO@ comes out as extremely cold liquid, instead of cool gas. Can anyone confirm this?
    Pittsburgh, PA
    Re: Co2
    accidental double post.
    Re: Co2
    so i was thinking instead of using co2 what about compresed air
    A20A1's Avatar
    Sep 2001
    Re: Co2
    Compressed air to?
    Re: Co2
    intake
