I've narrowed it down I think to a bad wire
The ignition switch works fine
The cooling fan relay is good
The fuses are not blown
The thermosensor is good
The fans work
I checked the four terminals where the cooling fan relay plugs in
with ignition ON:
I get 12V on one terminal
continuity to ground on another
continuity to the fan on another
and nothing on the last one
I am supposed to be getting 12V on the last one with the ignition on II.
Who knows which color wire this is?
The shop manual says there should be a Bl/Y wire running to the relay in the fuse box but there is no Bl/Y wire going in there.
