Page 1 of 7 12345 ... LastLast
Results 1 to 25 of 161
Thread: B-Series + 86 Hatch = this thread..(56K NO WAY)
    Required to do this swap
    1. Place Racing Motor Mounts (these have been discontinued, but a forum member built his own mounts) EDIT: Innovative has decided to start making B-swap mounts again. I cannot confirm that these will work with all the parts I have listed here, but it is very likely that they will.
    2. Passenger Axle: 87-89 Acura Integra Passenger Side Axle (A little long, but it works)
    3. Drivers Axle: The center shaft of the axle comes from the passenger side of the 86-89 accord. The ends (parts that connect to the hub, and to the transmission) are from an 88-91 Integra. This axle was put together for me by a professional axle shop, almost any axle repair place should be able to do it for you.
      (88LXi68, is running a 3rd generation(88-91) prelude drivers side axle for this application. I have not tried it out myself, but he has been running the PRI mounts much longer then I have)
    4. Place racing custom shift linkage (also discontinued, so good luck). This is an easily fabbed item. All you need is the stock Accord shift Linkage with and integra end (scroll down for comparison pictures).
    5. Custom Engine and Sub harness to convert to OBD-1 (I purchased mine from Rywire )
    6. Factory 86-89 Lx-i Accord Throttle cable (will work with a GSR throttle body bracket, and maybe others.)
    7. You can use a factory 86-89 Accord clutch cable but it is a little long. I recommend using an 87-91 Acura Integra clutch cable, it fits just right in the engine bay.
    8. You must use the rear engine/transmission mount bracket from a 90-93 Integra.
    I used the factory 86-89 Accord fuel line, it bolts right on. With the coolant hoses I had to use the upper radiator hose from the Accord with no problems, and the factory B-series lower radiator hose. With the lower hose you will have an issue if you are using the factory Accord radiator. The lower hose has a larger diameter then the Accord hose, Just make sure to use a very sturdy clamp on the hose that you can tighten with a screw driver or ratchet.
    I also did a wire tuck to clean up the engine bay a little that can be found here .
    Small video of the car in action
    Here are the specs on the motor
    1991 B18a bottom end
    Stock pistons bored .20 over
    ARP head and rod bolts
    Fully balanced/shot-peened and all parts were coated
    New GSR/R Fuel pump and water pump
    Lightened flywheel
    GSR head Milled just a little
    Cosmetic thin head gasket
    STR Cam gears
    AEBS intake manifold with stock GSR TB
    Ebay Megan racing header modified with a 2.5 Collector
    2.5" Pipeing all the way back to a vibrent Racing muffler.
    Check here to see my suspension setup.
    Installed
    Here is the Transmission Side Mount
    With out the engine installed
    Here is the Block mount
    Shift linkage End
    Shift Linkage (Factory on top/PRI on the bottem)
    Another comparison
    Engine Install Shot
    Side Shot
    Re: B-Series + 86 Hatch = this thread..(56K NO WAY)
    Cleaning up my thread...
    SEi User Deadhead's Avatar
    Jul 2005
    Loveland, CO
    Nice job, Did you get ahold of a pair of the placeracing mounts? Or did you custom fab your own?
    Hope you figure out the fuel problem.... and hopefully it's not a wiring problem and the fuel injectors are just clogged.
    Dec 2003
    1987 HONDA ACCORD 1.6 EX
    GREECE
    Congrats Legend Master for you car, superb work!!!!!nice N/A sleeper!!!
    Enjoy your new LS/VTEC engine.
    I think you are over 190hp with that set-up? with a nice ECU.
    Try also to change the LS tranny with a jdm S1 or Y1 tranny.
    ACCORD 3G RUNS FOR EVER
    Quote Originally Posted by Deadhead
    thanks, I hope that it's easly fixable, but I won't know untill next paycheck .
    Quote Originally Posted by Lok
    I think I am close to 190 at the motor, but I wish I was close to that at the wheels. I wanted an S1 or Y1, but they are rare and vary expensive. I got this tranny for $150.00 and the only Y1 I can find is $500.00.
    SEi User PortugalFocus's Avatar
    Sep 2003
    '13 Civic Si 4dr / 05 Saturn VUE 2.2L 5-Spd
    Clearwater, FL
    Looks like a lengthy job but I hope you get the injector problem sorted out.
    What's the deal with no timing cover?
    1988 Honda Crx Dx Mini-Me
    Columbus, Indiana
    with a nice ECU.
    Yeah a hondata!
    Nice job!
    LX User Sporno's Avatar
    1987 Honda Accord LXI
    Richmond ,VA
    i love the pic of the engine going into the engine bay
    2006 NASA/VCU regional Semi-finalist
    2006 FIRST Robot Rumble Quarter-finalist
    2006 FIRST Robot Rumble - Most Promosing Rookie Drive team.
    2006 Championship Curie division
    2007 NASA/VCU- Regional Winner
    2007 Championship-Galileo
    74+ matches on the feild
    Quote Originally Posted by PortugalFocus
    Theres no need for it, I have had lots of friends drive around for years without one.
    Quote Originally Posted by 3rdgenhatchDX
    Yeah a hondata!
    Nice job!
    I am running uberdata right now for the ease of tuning myself, but I can't really tune it untill I get it running .
    Quote Originally Posted by Sporno
    There is something about that lighting that makes it look like art .
    Banned
    sounds like a nice and solid set up on the motor. good job, good luck getting it to run right.
    Quote Originally Posted by JDMH22aAccord3g
    thanks we will se how it turns out.
    wprocomp's Avatar
    Armrest whore
    hey when we gonna meet up I wanna see this car man,I need to see wether or not I wanna put this b-series in the accord or not,looks awesome though man,last i saw that car was when ace had it
    Quote Originally Posted by wprocomp
    we need to have a TX meet or something, actually od2681 was the previose owner of the car.
    wprocomp's Avatar
    Armrest whore
    hey you gonna do rear disc swap at all,there was an sei at the yard about 2 weeks ago,if its still there I might be able to go get the disc off it
    I have already done it. You should still pull that swap and sell it.
    Nov 2002
    Ridin Dirty in New York
    looks great! Hope you turn some quick times with it
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Good work. I see you tried to paint the mounts like I did. What a waste. LOL! That shit scratched right off. Anyway, good to see another B-series up and running.
    Jul 2005
    Loveland, CO
    So what's your next project? B18 turbo?
    Aug 2004
    Nice! Congrats on all the work. Now give us all the low down. How long to complete the swap? Place Racing mounts or Custom Fab? Good job either way. I can't wait to hear how this thing drives.
    For Sale:
    T3/T4 Turbo, wastegate, and BOV
    P75 ECU
    Untouched Head
    Port & Polished, 5-angle valve job, bowl and swirl job, Head -$1000 invested in machining alone
    Misc.
    DDR Pad and DDR Extreme
    PS1
    NES
    Needed:
    Dremel
    Money
    Idaho
    Noice!
    '02 RSX-S
    Virginia
    nice
    Quote Originally Posted by w00tw00t111
    Well it took me a year or so to collect all the parts an build the motor, but to pull the other engine out and slap this one in it only took 2 days. If I get it running tonight then it will have only taken me a week or so to get it going. I used PLace racing mounts and shift linkage, Rywire engine harness (still under construction), and I used factory integra axles (but I don't know how well they work just yet).
    All just keep that my little secret , even though wicked already beat everybody to a turbo B-series J/K.
    Quote Originally Posted by SteveDX89
    I figured it wouldent last, but I really dident like those yellow mounts .
    and thanks to everybody else for the good replies
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    my hatchie envys yours
    3Geez resident body man
    Owner of Wreck-less auto body
    Accord of the Year - 2008
    TWOLOUDNPROUD's Avatar
    May 2003
    My God that 86 Hatch is full of
    Jul 2005
    Loveland, CO
    Quote Originally Posted by TWOLOUDNPROUD
  2. Rendons Offical A To B series thread!!!!
    By Rendon LX-i in forum Performance
    Last Post: 02-06-2013, 12:06 PM
  3. Some 720p footage of my B-series hatch. (old RaceTek car)
    By ZackieDarko in forum Classic Honda Pics & Videos
    Last Post: 01-13-2011, 09:50 PM
  4. My B-Series Swap Thread
    By OldSkoolA20accord in forum Classic Honda Community Chat
    Last Post: 02-12-2009, 06:29 PM
  5. HATCH pics thread... ...let's see 'em
    By markmdz89hatch in forum Classic Honda Pics & Videos
    Last Post: 04-13-2007, 09:56 AM
