Page 1 of 3 123 LastLast
Results 1 to 25 of 61
Thread: No, it can't be that stupid!
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    I installed my headers on my car, after getting mideval on that EGR line for about two hours. Get everything bolted on, all pretty looking. Hop in, get ready to test those bad boys out...
    Car won't start.
    BAH! I checked EVERYTHING, making sure I put back what I took off... Eventually after no luck, I decided that I had damaged the wiring harness. After about a day and a half of checking everything again and taking apart that section of the harness, I glance at my ignition coil for half a second to see one of the positive wires disconnected.
    I say to myself "No! No, it can't be THAT goddamn stupid!!!" Wire it back in, turn the key and VROOM, purrs like a kitten.
    I bashed my head on the hood a few times to make sure I remembered that :lol
    Anyone have any 'It can't be THAT stupid!' stories about your cars?
    -5150
    glorious!
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    one time, i put a new battery in my truck, and it wound't start. i checked all fuses but nothing, check starter, check fuel pump...yeah uhmmm i put the battery in backwards
    DOH!!!
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    change my plugs, wires ,distruibter cap, and it wouldnt start turned out it was a wire off my ingniton coil also. took me about 2 hours before i realized it
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Cut off my power steering belt instead of my A/C compressor belt
    shepherd79's Avatar
    Falling Waters, WV USA
    one time i forgot to connect coil wire to the distributor cap. It took me almost hole day untill my friend came over and pluged it in.
    i was ripping my hair onmy head. and i think that is why i am loosing hair.
    87 4dr lx, 91 CRX Si, 92/civic/hb si, 94 mustang GT conv.
    b'ham AL
    SteveDX89 Cut off my power steering belt instead of my A/C compressor belt
    OMG!! When did you realize you cut the wrong one?
    87 4dr LX "It was FREE"
    91 CRX Si it was only $500 hehe
    '85 lude
    houston
    i have 2 dipshit stories.
    #1 when i put my LXi engine in, i took apart everything i could think of to clean it. i had everything wired, all together and was confident enough to start it.
    not a damn thing happen. so i went through so much crap for a week and a half. then i finally got it running by taking off the vacuum advance diaphram and playing with the timing with a wrench while someone turned it over.
    i put the reluctor on backwards. took 2 min to turn it over and it ran great from then on.
    #2 (enjoy this one) : i had just gotten gas, and was about the only time in the world i cared what mileage i was getting. i put the gas in, put it all up and got in the car. started it, pulled out to the road and it was clear so i went.
    ok, this is all going on at the same time..... at that very instant i thought about reseting the odo. so i reached through and pushed the button. through the steering wheel. while i was turning. i had to straightin out, so with my right arm i was turning the wheel back. into my left arm. it turned a bit then my arm snapped off the blinker switch lever and stopped. the car kept turning and i did a u turn straight into the curb right next to where i just pulled out from, running the tow hook onto the curb.
    with oncoming traffic. so with the lever hanging down by my leg i pull my arm out real quick, put it in reverse, broke it loose, then threw it in first and hit about 60mph (in a 40) to make the next light.
    there was no way in hell i was gonna sit there in traffic next to the people that just saw me make a total ass of myself.
    LXi User 87Hybrid's Avatar
    2002 Chevrolet Silverado, 87 Hybrid Civic, 76 Chevy Blazer, 2000 Jetta, 1985 Civic sedan
    Battle Ground WA.
    Wired the spark plugs backwards spent 3 hours turning the distributor trying to get it to fire on all four.
    "AAHHH Teamsters, If only I could be as lazy and surley as a Teamster." Quote by Homer Simpson
    1989 DX R's Avatar
    Jul 2001
    1989 Accord DX ... 2001 Accord LX
    Texas
    Forgot to plug in my headlights when I replaced them. Whoops.
    Good bye to the 1989 DX Type R. Hello 2001 LX.
    DX:
    "Four wheels, four doors, and no frills."
    LX User chiller670's Avatar
    88 accord lxi ... 95 integra LS
    IL
    same here but i forgot twice
    95 teg LS
    Oct 2001
    87 Accord EX , 5spd , Manual
    forgot to put the engine's ground !! took me two hours to figure it out i even checked the whole electrical system !
    MIKE
    Jun 2001
    Boston MA
    lol, this has to be the funniest!
    S.Q.U.A.D. Engineering
    www.squadengineering.com
    DOH
    I cut my sprint springs the other day, everything worked fine, then it started making a grinding niose when driving, i was like oh shit, jacked up the car only to find that the lugs were only hand tight and the wheel was jiggling around in there. im just dumb
    Aka mugenaccord from the ole ole ole board
    Pheonix Red CA6 -- Sold
    Grey ED6 -- current project
    2005 Mazda 3
    Ontario Canada eh.
    lol, i did the same thing (minus the sprint gutting)
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    I pulled the lower radiator hose fitting off my radiator when I was changing my hoses. Had to replace a perfectly good radiator (minus a hose fitting).
    Mike
    1988starter
    Guest
    My GF put windshield washer fluid in the PS hole and one tme I was working on her car and could not get it to start well the neg side of her coil had come undone
    Jdub07's Avatar
    1986 Honda Accord DX Hatchback
    Newark, CA
    Changed spark plugs and wires went to start her up and nothing...I didn't plug ANY of the new wires into the distributor.
    Another dumb ass thing was, I did an oil change and could smell burning oil. I figured I must have spilled a little and it was burning off. After about a week it still wasn't going away so I poped the hood to find my oil cap up in the corner of the engine compartment. I never put it back on.
    And I lock my keys in the car ALLLLLLLLLL the time. If I get gas I leave the keys in the ignition well when my door closes more times than not it will lock itself! Pisses me off. I have a plastic AAA key that opens the door for that problem.
    86 accord dx wrecked
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    I didn't notice I cut the power steering belt until I drove it. I was pissed.
    Oct 2001
    my brother poured gas into the radiator instead of coolant ! ( i posted that a while ago ! )
    MIKE
    1988starter
    Guest
    MIKE
    I remember
    Jul 2002
    88 accord ex-i, 88 prelude Si
    Canada
    I thought you couldn't lock your keys in the car? My driver door doesnt lock unless the door is shut.
    Now:
    -1988 Honda Prelude custom
    -1988 Honda Accord (to be fixed and sold)
    Soon:
    -some big 4x4 truck
    -91 Acura NSX
    http://www.hatetofeelband.com
    SEi User jigga225's Avatar
    Louisiana
    not me but.....
    Me and my pops were talking one afternoon and he was about to leave the house in his Chevy Truck, He had the hood open becasue he has to add oil now and then
    He was drinking a coke out of the can, and talkin to me at the same time, and YEP poured coke into the engine.
    He was like aahh dammn!!!!!
    Chevy's still kickin though.
    Oh yeah I drove with the E-Brake on for about a block once!!!
    2005 Mazda 3
    Ontario Canada eh.
    he's got power locks i think
    Oct 2001
    here is something that you should all be carerful about it !
    i was working on my friend's Peugeot with power locks and the key was inside of the car , all windows close ! and i disconnected the negative from the battery and after i finished i put it back on again ! and walllaaaa! the car locks auto matically !!!!!!!!!!!!!!
    thank god we where near his house so he grapped the spare keys !
    so when working on a car with power looks ! KEEP AT LEAST A WINDOW OPEN !!
    MIKE
    Jdub07's Avatar
    Newark, CA
    nope I have a dx....the locking mechanism on the inside is so old and used that when the door shuts the impact of it closing will sometimes move the little switch causeing the door to lock. I always forget. Sometime the wind will close the door and lock that mother. Its like the car is fuckin with me and is laughing on the inside watching me try and get back in
  1. A stupid is as a stupid does
    By phrenology in forum Classic Honda Community Chat
    Last Post: 09-26-2010, 07:47 AM
  2. Stupid car!
    By 88accordalltheway in forum Classic Honda Pics & Videos
    Last Post: 10-26-2005, 02:38 PM
  3. I'm stupid need help
    By #4bandit in forum General Engine Swaps
    Last Post: 08-29-2004, 09:44 AM
  4. Stupid stupid car!!
    By Hash_man_Se_i in forum Classic Honda Community Chat
    Last Post: 12-06-2003, 09:32 PM
  5. stupid oil pan
    By 88fasthatch in forum 3geez Accords
    Last Post: 09-08-2003, 07:16 PM
