ok i swaped the efi of the bt and on the a20a1's block it seems to b lacking power y? r the heads differnt from one another? do i need to change fuel pumps?
The fuel pump should be the same for all the injected engines. The only diffrence I can see here is that the compression on the A20A3 is higher. You should still have more power than your previous manifold. What did you do with the secondaries. Are they just not hooked up to anything?
