OK I'm looking at the b18 manifold swap should I buy THIS ONE?
definetly a D series manifold
says NOT B in the title
http://cgi.ebay.com/ebaymotors/BLOX-...QQcmdZViewItem
that would work though...
yea its a D series....even if it werent it would be gay cuz u want a 70mm TB anyway. said that one only accepted up to 66mm
im not sure which manifolds have larger than a 65mm opening for TB's
my AEBS manifold only had a 65mm opening, i had to open it up to 68mm![]()
which is better the obx or aebs??? or victor x![]()
Fuck it....I'll prob just buy a skunk 2 or a venom....I plan on turboing it anyway.....
Originally Posted by Bglad420
ummm, skunk 2 is basically about the same as stock, and a venom is way to much money id either go with AEBS or Victor X
skunk2 is great for n/a, way better than stock a20/b20. not much better than teg type R manifold... BLOX flows just as well as skunk2 for way cheaper.
bury the bach.
http://home.stny.rr.com/versanick/burythetach
Originally Posted by Versanick
i meant the stock b18 not the a20/b20......
I would assume a minimal power gain. don't spend too much money on a stock one though, since blox's are only $150..
good luck
bury the bach.
We already discussed some of the manifolds available... check out the pics and such.
https://www.3geez.com/forum/showthread.php?t=42065
