Results 1 to 3 of 3
Thread: VSS code 17 in Integra
    1986 Honda Accord EX (1.6) carb Manual
    Karachi Pakistan
    Im stumped, I swapped a B16A into an 1g integra which originally had the D16A2 engine, its some real stupid EDM model which did not use VSS - after every wiring thing sorted out Im stuck with the VSS code 17 and VTEC wont kick in.
    I got a JDM pgmfi speedometer with some type of cruise control speed sensor in it along with a buzzer, and a circuit board with a 12 pin yellow connector in it. I cant find any two wires that show continuity when the speedo is spun.
    anyone here that can help me figure it out.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: VSS code 17 in Integra
    Check for a broken wire near the VSS sensor close to the front wheel. Also try a continuity check on the same wire back to the ECM from the VSS.
    Might need to unravel the wiring loom to check for a broken wire.
    Karachi Pakistan
    well problem solved, made a hybrid speedo from a 3gee cluster with its simple and mechanical speed pulser
  1. code 12
    By VIPER1988 in forum EFI Tech
    Last Post: 06-08-2010, 06:17 AM
  2. ecu code 10
    By import racer in forum EFI Tech
    Last Post: 09-16-2009, 04:03 PM
  3. 88-89 Integra engine code?
    By Sabz5150 in forum Classic Honda Community Chat
    Last Post: 01-14-2004, 09:15 AM
  4. #6 code
    By dhcarss in forum EFI Tech
    Last Post: 05-17-2003, 12:38 AM
