I was wondering a few things about the front camber correction for our cars that can be grafted onto our 3g from like the 4th gen or something. The parts listed below are all from a 4g accord.
Adjustable Ball Joint - Alignment Kit - Sliding Ball Joint - Front - Does One Wheel - Camber Adjustment Range +1.5 to +3.0 degrees
Control Arm - Alignment Kit - Uprights - Front - Does One Wheel - Camber Adjustment Range 1.75 to 3.0 degrees - For Cars Lowered 1.5" to 3.0"
The control arm would only work if the shaft bolt size is the same and the length of the actual arm bolt is long enough to go thru the full length of the strut tower.
Lets see what things can be adapted to our cars. I know this topic has been discussed before, but its been dead and gone a long time back.
