Results 1 to 6 of 6
Thread: which injectors to get???
    LX User 89accordlxi's Avatar
    see user name
    IA
    Question which injectors to get???
    I looking to order some injectors from nopi but am unsure which ones to get. what does "exc. Cal." mean? If I live in the mid west, do I get the ones with or without "exc. Cal."????
    Thanks for any help.
    Peace...
    89 Lx-i
    Performance: K&N filter,custom CAI, Accel coil, MSD 6aL ignition, magnecor wires, high flow injectors, FPR, sport exhaust,Tokico springs/struts
    Appearance: white gauges, side markers, headlight conversion, clear bumper signal/fog light conversion, SE-i center armrest and cupholder, SE-i leather seats
    17" ADRs with 205/40/17 khumos
    future plans: 16" or 17" rims(can scratch that one off the list 9-12-02), headers-high flow cat.-cat back piping. Rear disc brakes from SE-i, reground cam.
    OldSchoolSwap's Avatar
    88 Hybrid Accord LX-i
    Miami, Florida
    Get RC injectors.
    I don't know how many CC's you have but an upgrade can do some good in the long run after all your I/H/E are installed.
    http://vtecnos.tripod.com
    Member Since 7-9-01
    1988starter
    Guest
    where can you get them
    shepherd79's Avatar
    Falling Waters, WV USA
    ok, here is the formula to calculate what kind injectors you will need to get (i borrowed from JCwhitney webpage).
    To choose correct flow rate, multiply car's maximum horsepower (be realistic) by 0.45 (nonturbo engine) or 0.55 (turbo), then divide by number of injectors. If the number you get after computing falls between the flow rates listed, always select the injector with next higher rate. Example: If you own a Honda 1.6L 225 hp 4-cylinder, multiply 225 by 0.45 and divide by 4. The result is 25.31, indicating you should order injector with 30-lb./hour flow rate. Note: The brake-specific fuel consumption figures of 0.45 and 0.55 are approximate; dyno testing will give you the exact figure along with your exact maximum horsepower.
    89 SE-i Coupe
    Lancaster, Ohio
    exc. Cal means excluding California models. Those are the ones you want.
    89 Accord SE-i Coupe
    89 Accord LX-i Coupe
    '85 lude
    houston
    thats not entirely accurate, but it will work well enough i suppose.
    if our A20 made 200 hp at 6000k, but a build VTEC makes it at 9000, you can be sure the 9k is gonna need bigger injectors.
    also especially to keep from maxing the duty rate.
    then there is displacement... :p
  1. 4th gen injectors
    By import racer in forum EFI Tech
    Last Post: 12-09-2011, 01:52 PM
  2. injectors and an FMU
    By newaccorddriver in forum Forced Induction
    Last Post: 06-27-2006, 06:08 PM
  3. injectors
    By gp02a0083 in forum EFI Tech
    Last Post: 12-30-2005, 11:40 AM
  4. Injectors
    By Pharoah in forum 3geez Accords
    Last Post: 02-17-2004, 11:26 AM
  5. 88 injectors on 86???
    By od2681 in forum 3geez Accords
    Last Post: 07-23-2003, 04:39 AM
