What is needed to be added for an 89' Accord LX-i to have a turbo installed? What is needed to be rebuilt for the motor to handle it?
Everytime I searched I could not find what I was looking for, but I will look again.
https://www.3geez.com/forum/showthread.php?t=46593
read those then you'll get an idea of what is needed.
well on another note, i know i can do the mechanical work for the car , im confused on whats needed for fuel management
3Geez resident body man
Owner of Wreck-less auto body
well thast a given
you need fuel injectors, fuel pressure regulator and possibly FMU on the fuel side.
for timing side you need either msd btm, nothing (scary), static retard (lame), or obd1 swap so u can tune your ecu and handle both fuel and spark curves.
fuel curves, either SAFC, or obd1 swap that u can tune...
or if ur rich get the AEM EMS and call it a day..
ok now i was wondering even if i get a turbo that can do 5-10 psi will i still need to have a fuel management issue even with a low boost pressure? regardless of the transmission being auto, would the engine see any power gains from even 5psi of boost i would mabye have to expect a little bit better fuel milage
You will see some gains from any amount of boost. You will need fuel management no matter how much boost as well. You are forcing more air into the engine. Without additional fuel, you'll run lean and blow up your motor.Originally Posted by gp02a0083
aww i thought i coudl get away with runnin 5 psi and be ok with the stock system
With 5 psi, you can probably get away with just using an FMU.Originally Posted by gp02a0083
