Results 1 to 4 of 4
Thread: map sensor on 88 lx
    LX User alboy86's Avatar
    1988 honda accord lx
    san diego ca
    map sensor on 88 lx
    well i took cause my car is still running rich even after replaceing the o2 sensor he hooked it up to the sniffer whats werid is it only runs rich when theres a load on the wheels when hr revs the engine or lets the wheels spin freely it runs clean as can be bearly puts out above 0 on the hc so he thinks a load bearing sensor he thinks it the map sensor he checked the vac lines solinods everything took him about two days lol
    Oct 2000
    '88 Accord LX-i
    Connecticut
    Re: map sensor on 88 lx
    Carbed Accords do not have map sensors
    '88 LX-i Coupe --- LS/Vtec
    san diego ca
    thats what i thought the guy must of been looking at the fuel injected model of the parts sheet im still confused on what could be causing this problem something is not shuting off properly so a little bit if fuel is still getting in the carb i was thinking maybe its not warming up enough so its not getting in the closed loop mode causing it to run rich but we figured that wasnt it when it only runs rich when theres a load on the wheels
    How did he check everything and think that our car had a map sensor...
  1. cylinder position sensor and TDC sensor
    By newaccorddriver in forum EFI Tech
    Last Post: 04-21-2011, 10:02 PM
  2. Coolant temp sensor tw sensor
    By Bluntman in forum 3geez Accords
    Last Post: 07-06-2009, 06:12 PM
  3. cylinder position sensor and TDC sensor
    Last Post: 11-28-2006, 10:29 PM
  4. Need help! Broke a sensor wire (green sensor)
    By SMaurer32 in forum EFI Tech
    Last Post: 10-31-2005, 08:06 AM
  5. Quick, Which o2 sensor is the primary sensor
    Last Post: 11-03-2002, 07:23 PM
