Wife went to start the car this morning and nothing, no dome lights, no power. I thought it was just a bad connection so I cleaned the POS terminal and still nothing. So I get my battery load checker out to see what the battery showed. 5 volts, and zero on load. I think the battery just took a crap on me. Go get a new battery and a new terminal (broke the old one). Solder up a new terminal and throw in a new battery, and voila, she starts right up!
So, I hook up the battery tester to watch the voltage and see if it's charging like it should. As I sit in the car with it warming up, the battery light comes on. Hmm. I hop out and look at my meter. Showing almost 17 volts! When the cooling fans come on, it drops to about 14-14.5 volts., and then jumps back up to 16-17 volts when the fans shut off. I shut the car off and get the distinct smell of hot electronics. Sniff around under the hood and it seems to be coming from the Alternator. I'm guessing the Voltage Regulator is fried.
Question of the day: Is the Voltage Regulator part of the alternator? Or is it a seperate entity?? If I go get a new alternator and slap it in will this fix the problem?
Thanks in advance!!![]()
