Results 1 to 7 of 7
Thread: Very Dim Headlight
    Very Dim Headlight
    Hello,my right headlight all of a sudden doesnt work. the high beam works fine but the low is almost off. actually it looks like a headlight looks when the battery is dead it has a slight orange glow but it isnt working. the high beams are fine, i have checked the fuses under the dash and they are fine.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    Re: Very Dim Headlight
    sometimes thats caused by a crummy ground. see if you can find the grounding wire for that headlight. if you can clean it up that might solve your problem. Also, try cleaning the contacts on the bulb itself where it plugs in.
    Nothin' 2 Old Racing
    Blkblurr's Avatar
    Dayton, Ohio
    If it's just the low beams it will most likely be the wire going to the low beams is about to break. Check the wiring harness at the point it flexes when the headlights rotates and I bet you find a broken or near broken wire. The other thing could be a corroded connector at the headlight itself.
    i will check the wire. i dont think its the bulb because i put a different bulb in and it did the same thing.
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    I had the same sort of problem with mine, it ended up being a ground....so I'm with NXracer.
    LX User fraza's Avatar
    87 Accord Si
    Australia, melbourne
    if its a ground prob then wont both hi and lo beam be dim because they share a common ground, i lost hi beam in my left headlight, i fixed it just by unplugging the harnes and wiping of this creamy putty stuff on the contacts of the headlight and now it works fine
    dont worry mate, that'll buff right out
    Blkblurr's Avatar
    Dayton, Ohio
    Quote Originally Posted by fraza
    That's what I was trying to say in my post. can't be the ground because they're common for both.
  1. Headlight help..
    By CzEcHy in forum Interior & Exterior Care
    Last Post: 05-25-2009, 04:38 PM
  2. Headlight help
    By whyterice in forum Interior & Exterior Care
    Last Post: 01-17-2004, 09:28 AM
  3. headlight
    By Chadroper in forum 3geez Accords
    Last Post: 11-11-2003, 02:04 PM
  4. Ack! Need Headlight Help!!!
    By 3G Jester in forum 3geez Accords
    Last Post: 09-09-2002, 09:59 PM
  5. Right Headlight Is Dim
    By ‹^› ‹(•¿•)› ‹^› in forum 3geez Accords
    Last Post: 09-04-2002, 03:09 PM
