Results 1 to 4 of 4
Thread: Smoking from motor
    Smoking from motor
    I am having smoke burning from around the flange area that connects the header to the flex pipe. I crossed out the possibility that its my oil pan or oil pan gasket. Also that it can't be my oil filter gasket. My valve cover gaskets seems sealed pretty good and the head gasket is definitely not blown. Could it be that the gasket is burned out causing fumes to come out of it. The thing is it smells like oil. Any answe would help.....thanks
    Re: Smoking from motor
    Quote Originally Posted by sweetdang
    im guessing it's the vavle cover gasket dripping oil onto somthing hot and it burns and makes that smell
    10/Honda/Ridgeline
    NJ
    check the oil filter base gasket, If u are leaking from there, then there is a chance u might be burning the oil thats dripping onto your exhaust pipe. Also, if your PCV canister is leaking, then its a possibility. Best thing to do is to go under the car and then looking at it from bottom up.
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    I had the same problem with my 89 SE-i. i replaced thevalve cover gasket and the gasket/ o-ring behind the oil filter assembly. That took care of the problem.
  1. Smoking Brakes
    By HONDAMAN222 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-24-2012, 12:14 AM
  2. Motor smoking help
    By rsxguy in forum EFI Tech
    Last Post: 12-28-2007, 12:14 AM
  3. Smoking, in the bad way
    By SmokeyTheBear in forum 3geez Accords
    Last Post: 08-27-2006, 11:43 AM
  4. Smoking at WOT
    By mag_pbg in forum 3geez Accords
    Last Post: 06-26-2005, 09:26 PM
  5. Smoking engine
    By A Dawg Jr in forum 3geez Accords
    Last Post: 12-10-2003, 12:45 PM
