Results 1 to 3 of 3
Thread: Gas Gauge
    1988 Honda Accord Lxi
    Gas Gauge
    Alright my fuel gauge is not working right and it hasent been for like 2 weeks, At first it was sticking on the half way mark on a full tank of gas and wouldn't go up and then when it got lower than a half tank it finally started to go down and then when i stop it would show almost empty and then when i drove it would go almost half full im like wtf make up your mind.... I checked my intank sending unit and hooked it up to a ohm tester and it tested fine the resistor is working. What else could it be? Gauge cluster? maybe
    shepherd79's Avatar
    Falling Waters, WV USA
    Re: Gas Gauge
    well, did you check the float on the sending unit for any leaks. it could be that fuel is getting inside the float and it sinks.
    if the float is good, you may want to replace the gauge. it should be easy to do. when you get the new gauges, just replace the speedo gauge (to keep the miles ). Don't try to replace the fuel gauge because it is very fraguile.
    i hope that will fix the problem.
    Re: Gas Gauge
    Thanks man i will look into it
  1. A/F gauge and Water Temp gauge
    By smufguy in forum 3geez Accords
    Last Post: 02-29-2004, 09:29 PM
  2. Psi gauge
    By Morbid Intentionz in forum Trading Post
    Last Post: 01-05-2004, 10:17 AM
  3. need help with gauge
    By Dave-hid in forum 3geez Accords
    Last Post: 11-07-2003, 03:36 PM
  4. gauge help please
    By 90CRX in forum 3geez Accords
    Last Post: 03-04-2003, 10:18 PM
  5. Gas Gauge?
    By foxracer22 in forum 3geez Accords
    Last Post: 07-20-2002, 06:26 PM
