Results 1 to 15 of 15
Thread: suspension set-up for 3g's
    LX User cardoc33's Avatar
    88 accord lxi hatchback
    sf bay area
    Ok, I've given this some thought, and would like some feedback as to what everyone thinks about it.
    Front:
    stock GR-2's or HP's
    adjustable spring perches(Ground Control,ect...)
    250lbs spring rate
    S.T. front sway bar
    Rear:
    civic shocks with adjuster on body of shock(will explain later)
    250+spring rate
    S.T. rear sway bar
    Now here's the tricky part. We would need to have an adapter made for the short civic shock. All you machine shop guys listen up. An extender that screws on to the top of the shock rod with correct diameter at the other end to interface with the stock top mount. I beileve the extender would only need to be about 3" long.
    OK, there, I said it. Now, what are you going to do about it?
    Best Price on Clutch Repair in the Tri-Valley
    http://www.trivalleyclutch.com/3gparts
    OEM quality parts for your 3Gee
    Feb 2004
    89 accord lxi
    down by the bay
    Re: suspension set-up for 3g's
    IMO, i would go with a slightly lower spring rate in the rear and better shocks up front.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Quote Originally Posted by cardoc33
    It's not what we're going to do about it. It's what you're going to do about it.
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    ^^ Lol ya... doesnt sound bad, I'd go with HP's over GR2's... and how do u plan to have adjustable perches on either of those?... the HP's and GR2 do not have such a thing
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    Why not get better shocks and struts?? IE: Illumina??
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    i dont think they still make those for our cars
    -Gio
    My E85 Turbo Build
    5280FEST
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    They never made illuminas for our cars. One crafty member has adapted civic illuminas and agx's into his 3g (and, subsequently, his car f**kin' TURNS!!). Look up member Zufer--I think he's described his setup on here.
    Alex
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    Quote Originally Posted by 86AccordLxi
    Alex
    Thats what I was talking about, if he's gonna put civic suspension in anyways, why not get better shocks and struts.
    sf bay area
    Currently, there is no easy alternitive for front shocks on our cars. Yes, someone did make an adapter for the civic front, but it was a hassle. I suggested the hp's or gr-2's because it's our only cost effective alternitive. And use a spring rate that wont over power the shock(250lbs=211lbs x 18%). Then, use the thickest sway bar out there, Suspension Techniqes @ 15/16". Ground Control makes excellent adjustable spring perches.
    As for the rear, with the adapter I suggested, Illumina's are not possible because the adjuster is at the top of the shock rod. And yes, maybe 200lbs in the rear might be better.
    Front drivers handle better with a softer front set-up.
    Spending close to $1000.00 bucks for custom shocks(revalved Bilstiens) is out of most peoples reach(is for me). You could do this whole set-up for about $600.00
    smackers. Still alot, but better than a grand.
    I'm not going to do anything about it, I just bought a '93 teggy for $600.00 bucks. Cherry shape for for 200k miles. I'll put my suspension money into that and give my 3g to my kid who's 15 1/2 and wants to get his permit soon.
    Well first of all heavy-er front springs will give you under-steer and that will not help with cornering at alln it will only help at top speed. As for the civic struts in the front there is not that much involved in modifying the 88-90 font civic struts to make them fit. Actually they fit with no modification, but if you don't move the perch up on them they will wear them out pretty quickly. Here is my thread about the struts 88-90 civic struts. As for the rears, I never even thought about extending the rod to make them work, I always thought about trying to extend the bottom. You could get some internally adjustable struts like the konis and then you wouldn't have any problems making the struts work.
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    u are gonna have a ton of work just getting the shocks in, but kyb agx might be a good choice. also i would go with 350+ front and rear spring rates. 250 is pretty soft. i have 250 rear 350 front ground controls, and i would like to go 350/350 or 375 rear 350 front. springs are cheap from ground control...
    sf bay area
    What shocks are you running with spring rates like that?
    bobafett's Avatar
    Longview, WA
    with my 250/350 setup, which is what i am currently running i have konis in the front and tokicos in the rear ( i was like 17 and had no $$$ when i did that, i WISH i had bought all 4 konis)... the tokicos, even on 250 lbs springs definetly suck. i mean the car doesnt handle poorly, but i would appreciate a much more firm ride.
    i have 1092312983 other things going on with the car right now that is tying up $$$, but i plan on getting some new springs from ground control, and probably retro fitting civic shocks on there, so i can run AGX's or something along those lines, with external adjustability.
    Feb 2004
    89 accord lxi
    down by the bay
    i don't know why you would want the rear suspension that stiff. relative to the front of our car, there's like no weight on the rear. i know you want to tame as much understeer as possible, but you don't want the rear jumping around like a spastic cat.
    Jun 2001
    Boston MA
    i am so totally lost on suspension
    S.Q.U.A.D. Engineering
    www.squadengineering.com
  1. MPG and suspension
    By jasonrebellion in forum 3geez Accords
    Last Post: 05-06-2009, 11:32 PM
  2. 2nd Gen Suspension
    By Orion in forum 2geez Accords
    Last Post: 06-13-2006, 07:36 PM
  3. Suspension is done
    By Moodybluesr in forum Classic Honda Pics & Videos
    Last Post: 07-15-2004, 04:58 AM
  4. best suspension for my car
    By 89LXIGUY in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-24-2003, 09:10 PM
  5. What else to fix suspension?
    By Chrome_thangs in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-29-2002, 07:53 PM
