You should do a compression check with a screw type compression gauge, warm the car up to oprerating temperature so the rings expand first. I wouldn't be concerned with the first reading, but after 4 or 5 revolutions of the motor. The compression gauge has a pressure releif valve so it holds pressure untill you release it. That is the how I take compression tests on vehicles.
Interesting what your instructor is talking about, but ASE tests will not see that as significant readings though.
