Results 1 to 5 of 5
Thread: How do I bleed the clutch (96 Accord)
    I have a 96 Accord 4 cyl. that the clutch felt loose on. Checked the fluid reservoir and it was empty. Filled it up, it worked briefly. Now it doesn't again and I thought I'd bleed the clutch. Is this done at the slave cylinder? Where is it located? Thanks.
    Re: How do I bleed the clutch (96 Accord)
    i think you would get better help in a 6generation accord forum, this is for 86-89 accords
    Alright, thanks Sam
    I'll head there
    SEi User Deadhead's Avatar
    Jul 2005
    Loveland, CO
    No, he needs to go to a 5th gen accord site.
    86-89 = 3rd gen
    90-93 = 4th gen
    94-97 = 5th gen
    98- i don't know is a 6th gen and above.
    good luck with the clutch.
    Nov 2002
    Ridin Dirty in New York
    i bet your master cyl is no good, usually they leak like bastards after a while (usually leak inside the cabin)
  1. Need to constantly bleed coolant
    By DemonicAngel in forum EFI Tech
    Last Post: 08-05-2013, 08:21 PM
  2. Anyone bleed ALB brakes?
    By Nafs Asdf in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-26-2009, 09:45 PM
  3. Can you bench bleed a M/C on the car?
    By Sabz5150 in forum 3geez Accords
    Last Post: 12-07-2003, 09:13 PM
  4. How to bleed your brakes by yourself
    By POS carb in forum 3geez Accords
    Last Post: 07-22-2003, 02:48 PM
  5. how to bleed cooling system?
    Last Post: 09-06-2002, 11:06 PM
