Results 1 to 4 of 4
Thread: choke problems again..
    LX User DanG86LX's Avatar
    Jun 2002
    86 Accord LX, carb, AT
    Edmonton, Alberta
    The car was fine till this morning when it did not start.
    Well, I pump gas as usual 3..4 times (cold here ~ -10*C), crank up ok, kind of started for 2..3 sec then dead.
    Removed the air box, and guess what, the choke flap 3/4 open! Tried to move the flap by pulling the linkage but the flap did not move! How could that be? Fortunate, I got a spare carb from junk yard, so I removed the top hat and I saw the culprit, a little screw which secure the choke lever to the flap shaft. It was loose on my car. To tighten it u have to remove the little rubber cover on the right side of the shaft.
    I just wonder how many 3geez end up at junk yard bc of such a damn screw..
    LX User spnrx's Avatar
    1987 Honda Accord LX
    Austin, Tx
    Re: choke problems again..
    My car was having that exact problem. might you have any pics so I caould you know better understand?
    Catch me if you can!
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    It's the black rubber bit near the end of the screw driver
    Austin, Tx
    Thanks man!
  1. carb or choke problems
    By rustydx in forum Carburetor Tech
    Last Post: 01-10-2008, 02:51 PM
  2. choke
    By leem in forum 3geez Accords
    Last Post: 07-05-2007, 06:37 PM
  3. Choke problems.
    By Silver86LX in forum Carburetor Tech
    Last Post: 11-16-2003, 10:38 AM
  4. weber manual choke or electric choke?
    By myaccord7 in forum Performance
    Last Post: 11-07-2002, 04:27 PM
  5. Adjusting choke/replacing choke??
    By stylus277 in forum Carburetor Tech
    Last Post: 08-21-2002, 08:51 AM
