any chance an under drive pulley from 88-91 civic 1.6ltr will work on an A20?
DARKSIDE
WEBER POWER!
The thing about using that pulley is it needs to have the same thickness as the Accord crankshaft pulley does, so the pulley belts line up with the power steering & alternator. Other than that, the crank bolt needs to be the same diameter so the pulley don't wobble.
one of the biggest problems i found is that you have to change the power steering belt to the new ribbed style. Not too hard but after see how light our stock pulley is it seems hardley worth it. Plus I'm installing an 8lb flywheel. Thanks Thou
DARKSIDE
WEBER POWER!
although getting rid of PS is another blessing in itself. zeph posted an article on flyinmiata about converting PS rack to manual by modding the rack itself...
http://honda-tech.com/zerothread?id=1497586
http://www.flyinmiata.com/tech/depower.php
What pully is this ?
or is it the stock with the accessories removed and holes drilled?
I would like to reduce rotational mass wherever possible.
I think he is reffering to main pulley.
NO it won't work. you can try to make it, but as far as i know it won't work.
