Results 1 to 6 of 6
Thread: underdrive pulley
    LX User Darkside's Avatar
    Feb 2002
    A20A1 Weber Power
    Eugene
    underdrive pulley
    any chance an under drive pulley from 88-91 civic 1.6ltr will work on an A20?
    DARKSIDE
    WEBER POWER!
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: underdrive pulley
    The thing about using that pulley is it needs to have the same thickness as the Accord crankshaft pulley does, so the pulley belts line up with the power steering & alternator. Other than that, the crank bolt needs to be the same diameter so the pulley don't wobble.
    Feb 2002
    A20A1 Weber Power
    Eugene
    one of the biggest problems i found is that you have to change the power steering belt to the new ribbed style. Not too hard but after see how light our stock pulley is it seems hardley worth it. Plus I'm installing an 8lb flywheel. Thanks Thou
    DARKSIDE
    WEBER POWER!
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    although getting rid of PS is another blessing in itself. zeph posted an article on flyinmiata about converting PS rack to manual by modding the rack itself...
    http://honda-tech.com/zerothread?id=1497586
    http://www.flyinmiata.com/tech/depower.php
    What pully is this ?
    or is it the stock with the accessories removed and holes drilled?
    I would like to reduce rotational mass wherever possible.
    I think he is reffering to main pulley.
    NO it won't work. you can try to make it, but as far as i know it won't work.
  1. Alternator pulley sizes (OEM underdrive !?) Need your help guys
    By carotman in forum Restoration & Custom Fabrication
    Last Post: 08-30-2005, 08:11 PM
  2. underdrive pulley?
    By myaccord7 in forum Performance
    Last Post: 11-03-2004, 10:36 AM
  3. UnderDrive pulley damaging bearings?
    By hondamanlxi in forum 3geez Accords
    Last Post: 07-09-2004, 10:51 PM
  4. Someone Start A Underdrive Pulley Group Buy!!!?/??
    Last Post: 09-26-2003, 04:33 AM
  5. Underdrive Pulleys
    By Nate2310 in forum Performance
    Last Post: 11-10-2002, 08:51 PM
