Results 1 to 12 of 12
Thread: Changing trans fluid
    Apr 2005
    87 honda accord lxi
    Plattsburgh,NY
    Alright i posted this in someone elses thread but i cant seem to find the filler plug... The only thing that loooked like it was on the side of the transmission and when i pull that transmission fluid comes out... any thoughts?
    I would love a pic that shows the plug...
    Also the reason i am doing this is because in 5th gear i have a whinning noise... my gf says it sounds like when a plane takes off... i thought changing the fluid would be my first troubleshooting attempt...
    Apr 2005
    87 honda accord lxi
    Plattsburgh,NY
    Re: Changing trans fluid
    anyone have any idea where the filler plug is?
    i'm not real familiar with the manual tranny, but it should be the dip stick hole on the top of the transmission. i dont know any honda car that doesnt have it like that.
    Vanilla Sky's Avatar
    1999 Penalty Box
    dipstick is only on yhe auto trans.
    i believe it's another plug that looks like the drain plug, just up higher.
    Apr 2005
    87 honda accord lxi
    Plattsburgh,NY
    yea thats the one i thought too... but why would it be side ways? i looked everywhere for one but i couldnt find it... also how would i put in fluid if its sideways like that
    LX User Honda-Master's Avatar
    1980 Porsche 928
    Galaxy
    to drain there is a plug at lower part of tranny , you need a 3/8 inch rachet to remove plug,, when drained , reinstall plug, above rt axle there is a 17mm bolt, remove it, that's where you fill the tranny ,, use only motor oil 10w 30 works great,, get a little pump and pump oil in that hole till oil comes out,,it takes about 3 qts,,
    the reason 5th gear is noisy , most likely is because someone used gear oil in the tranny ....
    LX User 87AccordLXsdn's Avatar
    Feb 2003
    87 LX
    Savannah
    when filling it, just get a hose long enough to fit outside of the fender and attach a funnel
    April 1989 Honda Accord LX-i. A California car. (LeX-ie)
    Seattle WA
    I rescently had to fill my tranny for a clutch job. That big 17mm plug is the fill hole and you will need a funnel and a hose to fill it. MAKE SURE the car is level when you fill the trans. If you fill it with the front jacked up it will not fit the maximum amount of fluid in.
    Apr 2005
    87 honda accord lxi
    Plattsburgh,NY
    alright thanks guys u have been loads of help.. i wasnt sure if that was the right bolt or not... we didnt want to drain the fluid if we couldnt fill it back up
    oh quick question how much oil will it take to fill it back up?
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    2.5-2.6 quarts should fill it.
    Mike
    1987 Accord Lx - automatic-carb
    AZMIKE is right - under most circumstances, 2.5 qts. will refill a 3G automatic after doing a drain for a hr. or so.
    What I found is if you first drive the car and really warm it up, then drain on a flat surface OVERNIGHT for SEVERAL hours, 4 qts. gets drained instead of 2.5 qts.
    Since the whole system holds 6 qts., you get almost twice as much removed.
    Lester
  1. Trans. Fluid-
    By crwa in forum Classic Honda Community Chat
    Last Post: 06-02-2004, 09:38 PM
  2. changing trans fluid
    Last Post: 01-15-2003, 05:43 AM
  3. Changing brake fluid
    By anchovies in forum 3geez Accords
    Last Post: 10-14-2002, 07:18 PM
  4. changing auto trans fluid help
    Last Post: 10-02-2002, 07:25 AM
  5. [Engine & Transmission] Remove power steering (and changing PS fluid)
    By YK86 in forum How To
    Last Post: 05-29-2002, 01:19 AM
