Results 1 to 10 of 10
Thread: vaccum hose
    LX User Sporno's Avatar
    1987 Honda Accord LXI
    Richmond ,VA
    Exclamation vaccum hose
    yall know the 2 vaccum hoses coming out of the dizzy.well i went to replace the tube and it came off , but it took the peace that hooks on to the dizzy with it. the little think that sticks out that the tube goes on . an i im deep shit , what can do to fix it without buying a new one? also when i just started it up i must have lost pressure somewhere cause it was running really badly . the longer i let it run the better it got. its making sorta a popping noise , but i have concured that it is from my pos airfilter and its shield . so im gonna et a new K&N air filter
    2006 NASA/VCU regional Semi-finalist
    2006 FIRST Robot Rumble Quarter-finalist
    2006 FIRST Robot Rumble - Most Promosing Rookie Drive team.
    2006 Championship Curie division
    2007 NASA/VCU- Regional Winner
    2007 Championship-Galileo
    74+ matches on the feild
    Nov 2000
    Re: vaccum hose
    Here's an idea. Get a small brass hose coupling (small enough for your vacuum hose to fit on) with a barbed end on both sides. Drill out the hole in the distributor vacuum advance large enough for one end of the brass fitting to fit in about 1/2 or 3/4 of the way in and glue that sucker into the vaccum advance with epoxy or JB Weld. That should work.
    I replaced my vaccum advance when it would not hold vacuum and it cost me $75 at the dealer. It is $45 (plus shipping) from Majestic Honda.
    The hose couplings should be available at Home Depot. You migh be able to find one with small pipe threads on one end and a barbed connection on the other. With that one you could thread it into the vacuum advance.
    I've been improvising for years, what can I say!
    Richmond ,VA
    Re: vaccum hose
    thanks... are u able to post a pic. of what the thing looks like .. also u know the tube with single hose coming out of it. its like the size of a red bull can its near the break thing..i disconneted that and heard a pshht noise and some air came out also . i failed to memntion that that happened the same night. and i in deep S***
    April 1989 Honda Accord LX-i. A California car. (LeX-ie)
    Seattle WA
    Re: vaccum hose
    If you drill it out or jam something in there be careful not to get junk in your vaccume system. That could be all kinds of problems. Can you get to a junkyard?
    Richmond ,VA
    Re: vaccum hose
    i got a buddy hopefully going this weekend and he knows what i need. i was working on it today witha buddy and now its leaking some exhaust gas , with is probly a gasket. and its making some kind of popping kinds noise with we have no clue what it its. Im gonna take it to a shop. Thats my best bet.
    Nov 2000
    Re: vaccum hose
    The thing to which you are referring is the EGR valve. I had to replace mine a short while ago. You won't pass emission testing without it (controls NOx emissions).
    Richmond ,VA
    Re: vaccum hose
    the tube thing next to the brake thing , thats not a vaccum reserve canister that does somehting with power brakes. i need to know before tommorrow
    Seattle WA
    Re: vaccum hose
    Too many "Things" dog. I think you are talking abouth the break booster "thing".
    Richmond ,VA
    Re: vaccum hose
    ya its the brake booster thing . a guy on honda-tech told me whe i start it up to pump the brake pedal and i will refill itself
    Richmond ,VA
    Re: vaccum hose
    well i started it up after it all and it was running well. but i tried to drive it today and it shook like all hell it was like a seizure.
  1. Vaccum Box
    By 3rd Party in forum EFI Tech
    Last Post: 04-15-2011, 11:31 PM
  2. vaccum canister
    By stephensimmons in forum Wanted
    Last Post: 04-08-2010, 02:42 PM
  3. Vaccum
    By Janiel in forum 3geez Accords
    Last Post: 01-15-2003, 10:29 AM
  4. air intake hose. What kind of hose do you use?
    By Mike's89AccordLX in forum Performance
    Last Post: 08-27-2002, 05:25 PM
  5. vaccum hose size
    By Mantis88LX in forum Carburetor Tech
    Last Post: 08-14-2002, 04:54 PM
