Results 1 to 7 of 7
Thread: Boosted guys... What plugs are you running?
    Nov 2002
    Ridin Dirty in New York
    I have to check but it occurred to me i might be running BPR5EY-11 NGK-V power plugs... at 10psi im thinking about going to a colder plug (think BPR6EY or BPR7ES, the 7es is a standard plug but its MUCH colder than a 5EY) Your thoughts? Im trying to be on the safe side as much as i can to prevent any detonation...
    2.0Si User Elijah's Avatar
    Nov 2002
    A20A3T
    Edmonton, Ab, Canada
    I have check my part # I know they are accell
    Stop bench racing and pick up a wrench
    I know my spelling sucks and I suck with computers deal with it.
    S.Glastonbury, CT
    I have NGK's Irodiums as i just switched from the regulars so they last longer. I went up to 7's to be on the safe side. I would definately run more than a 5 since its something easy to obtain.
    Nov 2002
    yeah the 5ey is a hot plug... hopefully itll help me save my ringlands by going to a 7 range
    10/Honda/Ridgeline
    NJ
    DSMs run stock 14 lbs and they got 7s. If u want u can run them or even 8s. LIke Rob said and as u know, Iridium is the best of choice among boost nuts. So if you have 30 bux to shill out on just 4plugs, then get them.
    ps: our owners manual recomends BPR 6s and BPR7s (for hot climate) for stock cars, so ur way below normal dude.
    Nov 2002
    word... i know. I was thinking because 10psi doesnt seem to pull too much harder than 8 and it probably should, but im probably starting to ping and im running the stock ignition gap too...
    turfnnsurf's Avatar
    Nov 2002
    1991 Eclipse GSX AWD TURBO
    central NJ
    My 1g DSM came stock with NGK BPR6Es to run up to 11 psi stock. 11 psi is the stock Wastegate actuater spring rate on the 14b turbo. When I upgrated my fuel system and went to a larger turbo (now running 21 psi) I went with NGK BPR7Es plugs gapped at .28 Everything works great so far.
    Friends Don't Let Friends Drive Stock!
    [email protected] Englishtown, 4/24/04
    2005 It's 12's or bust!! All BOOST all the time!
  1. Boosted guys injector size?
    By stephensimmons in forum Forced Induction
    Last Post: 10-24-2010, 11:18 AM
  2. What do you guys usually pay for running and complete nonrunning 3rd gens?
    By LewZur in forum Classic Honda Community Chat
    Last Post: 09-24-2009, 01:35 PM
  3. has anyone boosted a b20?
    By 3geeandEF in forum Forced Induction
    Last Post: 09-04-2007, 02:26 AM
  4. What plugs are you running?
    By EricW in forum Forced Induction
    Last Post: 03-07-2007, 12:31 PM
  5. Boosted guys... What plugs are you running?
    By AccordEpicenter in forum Performance
    Last Post: 03-02-2005, 03:47 PM
