this will permenantly repair the oil drip issue from the oil pan plug after it has been stripped, no need to replace the oil pan.
You need a time-sert kit # 1415 from Matco tools
inserts 14 by 1.5
all the instructions will be included in the kit..
you also need a permanent oil valve , it is spring loaded, so you never have to remove it,, you can get the valve at,,,
http://www.fumotovalve.com/ ....or 1-425-869-7771....
the valve you need is F-106..
i have done dozens of these and they work great, you can also install these instead of the regular plug before it gets damaged, thus avoiding future complications,, especially if you take the car to those quick lube places..
__________________
Nice Asses I Like
Smart asses I don't
