Ok- i bought a remanufactured 32/36 holley carb for my accord. Im making a custom spacer/adapter- exactly matched to each bore size. im even going to port match it to my intake manifold.
is this a good idea?? or should i have an open plenum?>??
also i think my choke is coolant operated, it has a housing with an impeller, so im pretty sure that it is coolant operated. can i use the coolant hoses that run through the intake?? and just bypass coolant flow through the intake??
