I am in the process of building the Honda Acura hybrid transmission. There are three pieces to the housing. The bell housing, the middle section and the black cover that goes over fifth gear. If I understand correct, the middle section is universal between the two transmissions so the middle gasket would be the same as well. What about that black end cover though. Are they the same for both tranny's? I need to buy gaskets to finish this build and I want to get ones that will fit. I am using the Acura center section because of those big oil holes. Are all the gaskets compatible? Please help.(Meant to type GASKETS)
