Ok, so the fuel inlet is a 5/16" inverted flare.
The fuel line stock, is like a 1/4" hose, right?
Wondering what you guys have done... I've got everything to build an adapter, but will the stock fuel system fuel the Weber properly?
well the stock fuel line size is about the same as the holley/weber, much larger then the 1/4". It only went to 1/4 on our stock carb, between the filter and the carb.
once you remove the stock carb, no need to go back to 1/4", well assuming you've replaced the stock filter with something better.![]()
Gotcha! What size is the hose coming into the filter?
