does anyone know the difference between the different power mirrors honda used? almost all the ones I've seen had honda stamped on the back,the ones I found at the junkyard from an 89 lxi coupe have donnely stamped on them and don't say honda anywhere. they look too factory to be an aftemarket mirror,factory gaskets and interchanable mounting bases with the other mirrors,also a factory plug. maby they changed late in 89? they look much cleaner without all the stampings on the back,just the small script on the bottom,also just slightly different shaped.
