Ok, my car is running pretty good now and just passed the emissions test with flying colors a couple weeks ago.
It has since developed another problem which I believe to be related to the fuel pump, but wanted to bounce it off you guys/gals.
This first happened on Dec 23. I was driving along the highway at about 120kph (for about 15-20min), didn't notice anything strange. I went to accelerate further and NOTHING happened. It just continued at that speed and started to lose speed, I was barely able to maintain 110kph. Luckily my off ramp was about 15s away at that point. So I coast to a stop, stop at the stop sign for maybe 10s and then go to accelerate away. I floor it and it seems fine, no hesistation, just decent WOT response. I took a different way home, steady speed of 100kph, and no problems all the way home.
Today on the same route with warmer ambient temperatures I was cruising along and just wanted to see if it was doing it again after about 10-15min at 120kph. Sure enough, barely enough power to budge over 120kph. I downshifted to 4th and floored it and again next to nothing. I ended up pulling over because I couldn't even really hold 100kph at that point. I stayed on the side of the highway with the car just idling for a couple minutes. The idle was a little weak but it never stalled. I was trying to rev it and I had to floor it to get it over 4000rpms and even then it revved MUCH slower and sputtery. After a couple minutes when some throttle repsonse returned, I floored it and basically crawled back up to 100kph, but at least it was accelerating.
I got off the highway and stopped at a carpool. I left it running (again a little low and sputtery) and went looking for leaks under the hood, I couldn't find any. Its also next to impossible to see the bowl level with the air cleaner on, so....
I'm inclined to supsect the fuel pump is failing. I noticed the car sputtering a bit under light throttle a couple weeks ago, but it went away so I just thought it was shitty gas.
Opinions? Suggestions? As usually much appreciated since outside of this forum NO ONE seems to no anything about this car.
