Results 1 to 6 of 6
Thread: checking distributor advance mechanism
    1989 4 door SEi 5spd, 1989 4dr SEi auto, 1989 SEi coupe 5spd, 1988 LXi H/B auto (kids car), 1987 LX 5 spd (other kids car), 1988 Civic 3dr
    montana
    My vacuum advance is dead on my 1988 LXi. before I order a new advance - i figure i should check out the Distributor too - i.e. is the advace mechanism (stator) suppose to turn freely by hand and return on it's own?? No movement from stator when i apply vacuum to the vacuum advance so i'm wondering if the stator is froze-up as well...?
    thanks
    shepherd79's Avatar
    Falling Waters, WV USA
    Re: checking distributor advance mechanism
    grab the two vertical blades, and move it.
    most likely, your advance doesn't hold the vacuum.
    if you are going to order a new one, you better off ordering from Majestic or your local Honda dealer. Autoparts stores don't have the right part for EFI distributors. they have it for carbed TEC distributor but not for TEC efi one. I found that hard way. ordered 2 times and nothing matched. I went to dealer and they got the right part next day.
    montana
    I know my vacuum advance doesn't hold vac - just want to make sure the dist guts aren't toast.
    I'll check it out this weekend -
    thanks for the info.
    montana
    Thanks - I checked for free movement of the stator, and it seems to move easily by hand and return on its own. I ordered a new vacuum advance from the dealer. will let you know the results.
    Jul 2006
    For the TEC distributor, has anyone any firsthand knowledge of how exactly how many degrees the stator is supposed to rotate when turned by hand?
    Quote Originally Posted by onebad4D View Post
    It does move "a little" that is your mechanical advance plates under neath.
    I would worry more about it not hitting the reluctor when it moves.
  1. Hitachi Distributor mechanical advance
    By omianan in forum 3geez Accords
    Last Post: 12-10-2011, 08:21 PM
  2. Cold start distributor advance.
    By VTEC_Inside in forum Carburetor Tech
    Last Post: 11-30-2006, 06:14 AM
  3. distributor vaccum advance hoses
    By Bronx89lx in forum Carburetor Tech
    Last Post: 12-19-2003, 04:07 AM
  4. locking mechanism
    By 86accordhatchback in forum Interior & Exterior Care
    Last Post: 07-08-2003, 10:18 PM
  5. Replies: 2
    Last Post: 05-12-2003, 09:52 AM
