Results 1 to 6 of 6
Thread: Temp Guage NOT Working
    Temp guage not working checked all possible issues fans come on when they should thermostat opens when it should and replaced plung in engine where it hooks to. When i hook it up to the plug it peaks all the way out. Oh yeah even replaced the guage.
    Aug 2003
    1989 Honda Accord LX Coupe 5spd
    Re: Temp Guage NOT Working
    Follow the wiring, sounds like it may be a short if its pegging all the way.
    Honda, The Heartbeat of Japan...
    2004 RSX Type S
    1989 Accord Coupe LX 5spd 2bbl
    Slushies are something to drink, not drive...
    May 2003
    88 Accord LX 88 Accord LXi
    Change the temp sender and see if that does it.
    I did change the temp sender same thing ill try to follow the wire and see what i can find i thhhhink the wire is black with a yellow strip right.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Edit- After looking at this thread again. I will agree that is the temp. sensor, since it does it only when plugged in. Didn't look close enough at the problem.
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    if it peaks out when he plugs it in to the temp sender, he does not have a wiring problem. A wiring problem would show up whether it's plugged in or not. I suspect it's the temp sender. Replace it again. Mine did the same thing and the temp sender was bad.
  1. Temp guage quit working
    By nail4545 in forum EFI Tech
    Last Post: 07-26-2010, 01:48 PM
  2. Temp guage stopped working
    By MoDawG in forum 3geez Accords
    Last Post: 11-24-2007, 02:32 PM
  3. temp guage and oil press guage
    By buds302 in forum 3geez Accords
    Last Post: 11-17-2004, 09:12 AM
  4. Temp Guage Not Working
    By tightwhitelx in forum Carburetor Tech
    Last Post: 01-11-2003, 12:27 AM
  5. Temp Guage
    By Immeraufdemhund in forum 3geez Accords
    Last Post: 12-21-2002, 07:58 AM
