hi, there is the trouble.. the sound from the engine. the sound volume depends on rpms. the sound is like the bad bearing. i disconnect a generator too but the sound doesn't disappear. its seems its the main bearing but it could be waterpump bearing? i moved the water pump tooh-wheel with the screw-driver and it was loose a bit. so, what can u suggest me to do? engine: B20 . thanks
