Results 1 to 11 of 11
Thread: Suspension Restoration
    LX User 86-accord-lxi's Avatar
    ^My other asian body^ 1989 4dr lxi
    OKC
    I Have a 86 lxi sedan with 215,100 miles. all the front suspension bushings
    are cracked and rotted, But the rear bushings on the upper control arms are not. I have checked them all for play, and Find the rear passenger side upper control arm to have a little play. I can get a complete front suspension kit
    including inner/outer tie rod ends, upper control arms with ball joints, Bushing kit, and lower ball jonts for a good price. I can also get the rear upper control arms decently priced also. I can get all this for right around $300. Considering the age of the car, the mileage, and not knowing when, or if any of these parts have ever been replaced, Would you recommend replacing it all ? A buddy suggested that I just replace the one with play, But If I do one, I want to do it all at the same time. Is it worth it ? I plan on keeping the car
    as long as it will last with no major problems.
    Vanilla Sky's Avatar
    1999 Penalty Box
    Re: Suspension Restoration
    yes, replace it all. at this age with that many miles, it's a safety issue.
    OKC
    Just out of curiosity, How many of you guys have replaced all of your common wear suspension parts ? I guess I am going to go ahead and replace it all. Whats the usual price for a front end allignment ?
    anywere from $60 to $100 or so
    but it is smarter to get a all wheel alignment
    LX User paso100's Avatar
    Mar 2005
    1988 Accord LX-i sedan
    Central California Coast
    If you want polyurethane bushings (less play but firmer ride), go here:
    http://www.suspension.com/honda.htm
    Just make sure you use poly grease else they'll squeak.
    OKC
    Cool !! Thanks Paso.
    OKC
    Ghettogeddy, I don't think the rear needs allignment, The front will if I replace the tie rods, tie rod ends. Would it cost much more to do the rear also ?
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    ^^ Probably not, most shops charge a flat rate for a 4 wheel alignment.
    But ya i'm in the same boat as you, going to be redoing my whole front end here pretty quick once the snow melts, i'm sick of the clunking,.
    OKC
    Im gonna go ahead and replace everything, then have all 4 wheels alligned.
    I just hope it's worth at 215,100 miles. The only major repair I have had to do
    to my car is replacing the transmission. Other than that, a bunch of small
    stuff. I checked the compression and got 130 cyl 1, 120 cyl 2, 130 cyl 3, and
    150 cyl 4. The car tends to smoke for a little heavy on cold days for about 10 minutes, Then simmers down to normal exhaust. Im sure it's just the valve stem seals, or guides, or both But, I can get the stem seals and guides replaced, a 3 angle valve job, and mill for $150 But, I am just going to wait until next fall because by then it will be time to replace the timing belt and water pump.
    Quote Originally Posted by 86-accord-lxi
    were are u getting the rebuild kit at i might be looking in to one soon
    Banned
    89 Honda LX
    Beertown, USA
    Yeah, where is this kit at? I need to do this also, at 230,000 miles.
  1. SZfiftyfour's 2G Accord Restoration
    By SZfiftyfour in forum Project Central
    Last Post: 02-12-2017, 10:13 AM
  2. Restoration, when is it too late for a car?
    By stezie in forum Classic Honda Community Chat
    Last Post: 07-06-2011, 06:08 PM
  3. Bumper/trim restoration
    By Xaisk in forum Interior & Exterior Care
    Last Post: 10-20-2010, 09:41 PM
  4. Heat gun restoration
    By nswst8 in forum Interior & Exterior Care
    Last Post: 12-27-2009, 09:35 PM
  5. JDM 1981 3dr HB GX Restoration Pics (56K? might be OK)
    By epic1400cs in forum 1geez Accords
    Last Post: 12-22-2006, 04:23 PM
