Results 1 to 24 of 24
Thread: junkyard motor
    SEi User
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    junkyard motor
    im not sure if this is in the right topic or not, but im considering rebuilding an engine for my accord and i want minimal downtime so id probably have to yank out a spare motor from the junkyard. what are your thoughs on a motor thats from the junkyard? what kind of things should i look out for when im looking for a motor to yank out? and on a scale of 1-10, how hard is it to actually pull out? pretty much by doing this, it would give me time to put in the B16 intake manifold i have without having to put my car out for a week or so. and id have a somewhat fresh engine to play around with
    1988 Honda Crx Dx Mini-Me
    Columbus, Indiana
    Re: junkyard motor
    the local yard here sells pulled engines for $300, just have a truck handy
    SEi User
    Jun 2005
    Edmonton AB
    Re: junkyard motor
    Quote Originally Posted by 3rdgenhatchDX
    by pulling it myself itll only cost like $150CDN. it helps to have a truck though, so id probably have to rent or borrow one. what im curious about are the condition of the motor when im pulling it. i dont wanna pull a motor i cant rebuild or something to that extent
    1988 Accord LX-i
    Delaware County
    Re: junkyard motor
    Pulling a motor for less down time is a good idea. Just make sure you do a good visual inspection and make sure everything looks good, maybe check the milage and try to get a motor with low milage because it will probably be in better shape. It's hard to say a scale on how hard it is because it all depends on how much mechanical knowledge you have, what you know on how the motor and trans bolts in and if you have all the right tools.
    SEi User
    Jun 2005
    Edmonton AB
    Re: junkyard motor
    Quote Originally Posted by LiTtLe xOx BitT
    ive pulled maybe 3-4 motors out of cars before. none were accords though. ive done my own 5 speed swap so i should know where everything is. what im curious about is asides from looking at the milage a motor has, is there anything else i can do before i start pulling it out? ive pulled a tranny out and about a month later when i tried moving the car i had to pull a second one out due to the first one having plenty of sand within it and ruining it.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Re: junkyard motor
    I'd look for a car with obvious body damage, hopefully to the sides or rear. A car with a good body is more likely to have ended up in off the road due to mechanical problems that you may not find until you have the engine apart.
    Mike
    LX User kaltenacht's Avatar
    1987 Honda Accord LX-I 4spd Automatic.
    USA
    Re: junkyard motor
    I would agree with AZmike. Looking for a car w/ body damage is a good way to sort out motors. I car with collision damage, is there for obvious reasons... Although this is a good place to start, look at the engine for signs or damage, and overall shape. It would be better, in my mind, to buy a already pulled engine, because those are usually housed in a location away from mother nature. But even if you go with one you pull yourself, you really cant tell until you start taking it a part. For example a engine could look great on the outside, but once taken apart, you could have scratched cylinder walls. The point is be careful.
    "I contend that we are both atheists. I just believe in one fewer god than you do. When you understand why you dismiss all the other possible gods, you will understand why I dismiss yours."
    1988 Accord LX-i
    Delaware County
    Re: junkyard motor
    Yea, look for a car that maybe was totaled in the rear or side because then you know why its there. If you pulled motors and all before then it should be no problem for you.
    Jun 2001
    Boston MA
    Re: junkyard motor
    if the oil is still there check to see what it looks like, if there is any water in there. if the engine looks rusty it possable its been rain on and water got into the cylenders. also try cranking the motors to see if they spin, you ccan crank by either using a braker bar on the crank pully of bringing a 12v source to jump the starter
    S.Q.U.A.D. Engineering
    www.squadengineering.com
    SEi User
    Jun 2005
    Edmonton AB
    Re: junkyard motor
    i believe the accord should be easier then most considering im not putting the one in the junkyard back together. so im guessing its the side mount, front mount, rear tranny mount, and dog bone mount, then misc wiring/lines and then outs out? thats all i can really think of, asides from separating it from the transmission(which i could always use another one of)
    SEi User
    Jun 2005
    Edmonton AB
    Re: junkyard motor
    Quote Originally Posted by AZmike
    ill take this advice into consideration when i decide which one to pull out
    thanks for all the input guys
    SEi User
    Jun 2005
    Edmonton AB
    Re: junkyard motor
    Quote Originally Posted by SQ is the SQUAD
    they actually drain all the oil out before they put it out for us. i doubt i can get a battery in there and try to crank it over, but i can use a breaker bar to turn it though. should there be much resistance when im cranking the engine?
    SEi User halxi's Avatar
    88 LX-i Coupe
    Brighton, Colorado
    Re: junkyard motor
    if you plan to rebuild the motor, just make sure the block isnt cracked, or severly warped and you're alright.
    Sure the pistons might be trash, or everything internally for that matter, but if you're replacing it all, who cares?
    SEi User
    Jun 2005
    Edmonton AB
    Re: junkyard motor
    Quote Originally Posted by halxi
    pretty much. my motors leaking oil from somewhere and rather then having huge downtimes in the summer when i plan to rebuild, i might as well get a spare. parts shouldnt be too expensive as im just stucking to the typical auto store parts. the only thing im concerned about is the crank condition and such like that. but you do have a point in picking one which isnt warped or cracked though.
    88 LX-i Coupe
    Brighton, Colorado
    Re: junkyard motor
    on any motor rebuild, i would recomend getting the crank rebalanced and such. No point in rebuilding a motor on the factory crank that has how many miles, and how much crap built up on it?
    SEi User
    Jun 2005
    Edmonton AB
    Re: junkyard motor
    what kinda places rebalance crankshafts and how much does it normally cost?
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: junkyard motor
    <throw a few things in this thread>
    Lowest milage motor is a plus in some cases. Pull the dipstick out, look at the condition of the oil. Look at the condition of the spark plug wires. Pull the spark plugs out & see if you can turn the crankshaft bolt over. You'll be able to see the condition of the cylinder walls after pulling the head. Look for cracks between cylinder walls & around the head bolts. Have the block & head magnifluxed for cracks. Plastigauge the crank & rod journals.
    You'll need some precision tools to see what you have after you pull the motor.
    88 LX-i Coupe
    Brighton, Colorado
    Re: junkyard motor
    any engine shop should, a higher tech mechanic might be able to do it
    i think my friend matt got his crank balanced for his old a20 build for $200ish? but im not 100% sure
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: junkyard motor
    Crankshaft balancing is done at a higher end automotive machine shops. There are automotive machinist that specialize in crankshaft balancing. Here it runs about $150 for the crank give or take.
    SEi User
    Jun 2005
    Edmonton AB
    Re: junkyard motor
    hmm... what does rebalancing the crank really do? just makes sure that theres no excessive weight thats moving up or down in a particular stroke? if so, how important is it really?
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: junkyard motor
    You also can balance the rods & pistons too. Balancing the crankshaft & lower end basically makes sure that your engine doesn't vibrate at any rpms.
    SEi User
    Jun 2005
    Edmonton AB
    Re: junkyard motor
    not sure where to get the block magnafluxed, but how much would that normally cost?
    as soon as the junked car enters the yard, it goes into their ghetto shop where the gas is emptied into a container for their use and the oil and any fluid for that matter is also emptied to prevent a hazard for our safety.
    im not sure if its a good idea to pull out the head on an engine in the junkyard, but i guess i can probably do that easily though.
    ive already used stuff like plastigage and own torque wrenches. i guess i should buy a ridge reamer and one of those things to hone a cylinder wall while im at it cause id need those too. so much to plan for before i actually go on and pull out a motor. atleast the more knowledge i walk in with, the less money i waste
    SEi User
    Jun 2005
    Edmonton AB
    Re: junkyard motor
    by vibrate do you mean irregular vibrations? cause my motor at this moment is vibrating, but only when its idling and only when the revs jump up and down. asides from that she revs steady as a rock
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: junkyard motor
    Quote Originally Posted by newaccorddriver
    Irregular vibrations after rebuilding a motor. I need to add, if you want a good balance on the lower end, it includes flywheel, crank, rods & pistons..
    As far as your car vibrating, it could be many things which include faulty fuel injectors, faulty coil giving a no spark miss, faulty distributor, bad plug wires, foul out spark plug, broken engine & tranny mounts...
  1. Replies: 88
    Last Post: 08-10-2014, 08:59 AM
  2. Junkyard Motor And Trany
    By crucial in forum 3geez Accords
    Last Post: 02-23-2008, 09:21 PM
  3. Strange motor issue. (also what motor is in it?)
    By fotosoup in forum 3geez Accords
    Last Post: 11-21-2006, 05:45 PM
  4. Mugen b20a-3g accord motor or 3g prelude motor!
    By adams86lxi in forum Classic Honda Community Chat
    Last Post: 01-13-2005, 11:01 PM
  5. FS: 89 Prelude parts car, 2.1 motor, 2.0 motor
    By kicker1_solo in forum Trading Post
    Last Post: 09-16-2003, 07:00 PM
