Results 1 to 9 of 9
Thread: Replace Tranny = Idle Problem?
    LX User JFreddy's Avatar
    Mar 2004
    1989 Honda Accord ex-i
    Airdrie AB, Canada (By Calgary)
    Alright so I just put in my second tranny, because of lowering my car... yes lowering... but tahts another story i'll post pics to prove later. anyways I put in another tranny, start the car up and now its idling spiratically or however u spell it.
    like it will idle fine when started up, but if i rev it up or drive it when im off the gas the car will rev down and almost stall, then rev up and down for a few minutes. Now it seems alot like a vacuum leak, right now the idle is turned way up to compensate for it but i kno thats the wrong way to fix it and i cant find what is going on, coolant level is good. oil is up, I dont kno what else to do?
    Any thoughts of where I might knock off a vacuum hose while puttin a new tranny in? that i could miss when hooking everything back up? or what esle to check for?
    It's not what you drive, It's that you drive what you got! I LOVE MY 3Gee!
    Re: Replace Tranny = Idle Problem?
    Check for loose wires, disconnected wires, broken wires, wires that were relocated for any reason.
    PCV valve can cause a vacuum leak.
    Mar 2004
    I've checked for all the wire problems but I'll check the PCV valve
    DX User flexville19's Avatar
    1988 honda accord
    gat town
    check the vacum lines really close cause when i put my first tranny in i had the same problem and i finally fonund a a small hole in the hose where the tourqe bar mount hit it
    erotic tuner
    Mar 2004
    Where is the torque bar mount? is that the bar thats attached to the tranny?
    SEi User B16KILLA's Avatar
    SO,CAL
    Talking Re: Replace Tranny = Idle Problem?
    I think he's talking about the bar ("dogbone") that goes from the firewall and engine/tranny.
    Mar 2004
    OH... lol dogbone... theres the lingo I understand , How do u find vacuum leak holes? what if its a pinhole that cant be seen barely? My buddy told me to spray itnake cleaner on all the lines and if the throttle goes up then i've found a leak... woudl this work?
    TB cleaners... when sprayed into the leak... not the TB will cause the idle to shift around, then it'll go back to normal. So thats how you know where the leak is. The more directed and smaller the spray the more you can narrow down the search.
    Mar 2004
    Alright thanks.
  1. tranny shift problem possably bad tranny
    By xxxfrankensteinxxx in forum 3geez Accords
    Last Post: 05-05-2008, 08:50 PM
  2. accord lxi idle problem and start problem
    By sonusa in forum EFI Tech
    Last Post: 08-21-2006, 09:05 PM
  3. Fax idle valve, fix or replace?
    Last Post: 10-20-2005, 10:30 AM
  4. Replace idle mix solenoid w/ carb in place?
    By joebeets in forum Carburetor Tech
    Last Post: 03-19-2004, 09:49 AM
  5. eratic idle, engine light, and clicking from tranny
    By Tref_LXI in forum 3geez Accords
    Last Post: 06-14-2003, 12:09 AM
