Results 1 to 10 of 10
Thread: Idle adjustment?
    Apr 2005
    87 honda accord lxi
    Plattsburgh,NY
    Idle adjustment?
    Alright when im sitting at a light my rpm will be at like 600 or so is there any way to adjust the idle so it sits at like 900 or something? i am an lxi ....
    also i had another question
    when i shift into 5th gear it makes a whinning noise my friend has a 89 accord and his dosent make the noise....its only when i accelerate in 5th... dosent matter if im doing 50 or 60mph any thoughts? i just changed my transmission fluid thinking it may be that but it wasnt
    SEi User B16KILLA's Avatar
    SO,CAL
    Re: Idle adjustment?
    Theres a screw on the top of your throttle body, adjust that to the idle rpm you want.As for your tranny making noise ,sorry dont know.
    1997 BMW 528i, 1988 Honda Accord LX-i
    Chico, CA
    how many miles are on your car? I know that 5th gear is the first to go in high mileage 5 speeds...
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    I'm coming to the conclution that this 5th gear keeps going bad cause of using gear oil & not motor oil in the transaxle. The gear oil doesn't give the 5th gear good lubrication. Cause when I bought mine, & changed the transaxle fluid, it had gear oil in it.
    EDIT- This is assuming that you have manual tranny.
    Feb 2004
    89 accord lxi
    down by the bay
    correct way to set idle is with the eacv unplugged. if you plug the eacv back in and the idle goes up, you need to clean or replace your eacv. i think a lot of times people have the idle set too low to compensate for a dirty/malfunctioning eacv which will cause a loping idle under certain conditions.
    Apr 2005
    87 honda accord lxi
    Plattsburgh,NY
    where is this eacv?
    SEi User Deadhead's Avatar
    Jul 2005
    Loveland, CO
    uh... i don't even know what an eacv is, and i've adjusted the idle on my old accord more times than I can count (I tinkered with it too often :P)
    On your Intake manifold, there is a large hose that goes to your fast idle control valve. You need to take that off and plug the hose connection on the intake mani with a piece of rubber, or the end of your finger like how I did it.
    Then take a screw driver and adjust your idle to approx 750 rpm. Plug the FICV back in and your good to go.
    If you adjust your idle without unplugging the FICV, your rpm's will drop faster down to idle than it should be. Usually it goes to 1200 pretty quick and slows from there down to idle.
    If you only adjust your idle with the screw, oh well... not like it's going to hurt anything or affect your gas mileage that much... i just find that the car is smoother when adjusted properly.
    Apr 2005
    87 honda accord lxi
    Plattsburgh,NY
    well i think i may have fixed my idle problem... its seems to be running alot better at the moment...
    i had a cai and the pipe kept on falling off and so the idle would change cuz there would be no vacumm... seems to be all fixed now... got some good clamps on it and some extra duck tap to keep it on there nice and tight...
    Jul 2005
    Loveland, CO
    uh.... your CAI wouldn't cause you to not create vacuum... It could starve your engine if it somehow plugged the throttle body and that would cause it to affect your idle.
    Good to hear it's working good now though.
    Apr 2005
    87 honda accord lxi
    Plattsburgh,NY
    well im assuming the vacum lines that came off the air box used the pressure that the engine would make by sucking in air...
  1. Idle Speed Adjustment
    By DBMaster in forum EFI Tech
    Last Post: 07-30-2007, 03:56 PM
  2. need diagram for idle adjustment
    By fcov in forum Carburetor Tech
    Last Post: 07-27-2006, 04:08 PM
  3. wtf is the idle adjustment screw??????
    By Nospeed in forum EFI Tech
    Last Post: 04-21-2006, 05:41 PM
  4. weber idle adjustment
    By 87AccordLXsdn in forum Carburetor Tech
    Last Post: 02-14-2006, 07:36 PM
  5. Weber DGV Fast Idle Adjustment
    By Razor in forum Carburetor Tech
    Last Post: 04-13-2005, 01:03 PM
VigLink badge
